Going to be doing a 411 conversion on a 92 Buick Roadmaster Wagon. Will be changing the intake to a Pro Flow and the trans to a 4L60E.
Dennis
Dennis
One in the repository with 4L80, with 12212156 OS, so 4L60 segment swap is available from either F-body or trucks, both of which used that same OS.
I'll go grab that file and make the segment swap.
Thanks D
It is stock. I checked the VIN in the TIS lookup and every single one of the CVNs match, there are zero changes from stock in that file. Go run it yourself and you'll stop posting that there's something not right about the repository file.
https://tis2web.service.opel.com/tis2web/
VIN is 1GAHG39R621203269
So if it wasn't right for your specific non-stock combo then it's that file's fault? Jesus.
