Changing Stoic and user math
Trying to tune for 14.1 AFR, changed my Stoichiometry to 14.12 and my equivalence ratio commanded displays as 14.12 in VCM scanner, but my math seems to be wrong, because at 14.2 on my wideband it shows as rich on my eq ratio. I have the formula provided by 100*[(formula provided by AEM - which just converts voltage to a AFR) - equivalence ratio commanded]/equivalence ratio commanded. Equivalence ratio commanded in this case is channel 50118.238. I suspect that this channel is not the same as my equivalence ratio commanded displayed in VCM scanner. What do I need to change? If I turn on my fuel trims it also seems to set AFR back to 14.67?I know there is a way to do this because I?ve seen people do it, I just don?t know how.
