TCC Apply Pressure Ramp Table rows and columns different between tunes.
I recently read two 2011 CTS-V ECU's
On the first one, the TCC Apply Pressure Ramp column begins at -74 and ends at 516
On the second one the TCC Apply Pressure Ramp column begins at 738 and ends at 4,425
The rows are also different.
1) I don't understand why the non-editable values are different.
2) a range of 738 ft/lbs to 4,425 ft/lbs seems like someone modified the base table framework inappropriately.
Anyone know what happened here and if there is a way to change the table values to a different range? (resolution)
Thanks in Advance!
