Ford Raptor Wont Richen up past 3800 rpm
so I have a Ford Raptor on the Dyno...
and every thing is decent part throttle...
when we go WOT, about 3800 RPM (EVERY TIME) the fuel starts to lean out....and I cannot seem to richen it up
cant find what table is messing with the fueling keeping it from being able to enrich the fuel
Not sure if we are just missing something simple...or possibly missing one parameter that has some variable wee need to change....
Commanded AFR is Fine...stays right where we command it to be.
the Truck has a Procharger Kit...6-8 PSI total
Has 60 lb injectors...tested and flowed on our Injector machine
Fuel Pressure is being Logged on the dyno, and it stays Stable at 58-60 ish (and it has a Brand new Walbro 465 pump in the tank)
Its making about 320 HP to the tire on our MD-1750 Mustang Dyno
*Problem Solved... Files Removed from this post*
