Hi guys,
Did a log with version 3.2.146 and found the THROTTLE POSITION to be reading 39%.
Cheers
Attachment 64577
Hi guys,
Cheers
Attachment 64577
Must be normal if no replies
Remove the channel and re add it, then see what happens.
On GEN 4 computers, full throttle should be 87-88% and not stay stuck at 39%.
Thanx for your reply,
before I updated the software, full throttle was 87-88% and when updated it reads 39% full throttle.
I wanted to help, but didn't see your question or point. You just wrote your TPS was reading 39%. Like - and? Your speedo is also reading 113km/h, MAP 98kPa... in the pic. It looked like you just accelerated and held the throttle open at 39%.
So the problem is your TPS maxes out at 39%, right?
Try a different TPS gauge.
If all of them don't work right, make a custom one in Math Parameters.
And try what 5FDP wrote.
