The Table Editor Toolbar
The toolbar in Table Editor has many options for viewing and modifying tables.
Table Open, Save and Print
Import a table from a file and overwrite current table. |
Save the table to a file. |
Print the table. |
Favorites
Add this table to your favorites. |
Remove this table from your favorites. |
See Using Favorites for more information.
File Compare
View the table for the primary calibration |
View the table for the compare calibration |
View the differences between the primary and compare calibrations |
NOTE:
Reload
Reload the current table |
Copy and Paste
Copy table selection to clipboard |
Paste table selection from clipboard |
Modify
Replace selected cells with the value in the box |
Add the value in the box to the selected cells |
Multiply the selected cells by the value in the box |
Single View Vs. Split view
View only one data representation (table or 2D/3D graph) |
Use a horizontal split with the table display on top and the graph on the bottom |
Use a vertical split with the table display on the left and the graph on the right |
Select View
Selects the table view. In split view mode, the table is always one of the views in the split. |
Selects the 3D graph view. In split view mode, this changes between 2D and 3D graph view. |
Selects the 2D graph view. In split view mode, this changes between 2D and 3D graph view. |
Precision
NOTE: The functions of these two icons were swapped in VCM Suite version 4.12. (If you are using an older release, use the description for the other icon in this list).
Increase decimal precision (add a decimal place) |
Decrease decimal precision (remove a decimal place) |
Smoothing and Interpolation
Smooth the entire selection |
Smooth the selection only using a horizontal pass |
Smooth the selection only using a vertical pass When using the smoothing functions, the level of smoothing will be determined by your current precision. To increase the effected area of your smoothing, increase your precision |
Interpolate the entire selection (flat plane) |
Interpolate between horizontal bounds (creates lines) |
Interpolate between vertical bounds (creates lines) |
