Table Editor Right-click Menu
Right clicking on a table in the table editor displays the following options:
Copy
Copy a selected cell or section of the table to the clipboard.
Copy with Axis
This function copies a selected cell or section of a table and includes the axis data. When used in conjunction with the Paste Special function, Copy With Axis allows the data to be pasted into another table without selecting the destination cell. Because the data was copied with axis labels, the software will automatically place the pasted data accordingly.
NOTE: This is similar to the function in VCM Scanner's Graph panel and RTT Editor.
Paste
Pastes a cell or table section into a selected cell. When pasting a copied region, the selected cell will become the top left cell in the pasted region.
Paste Special
This function pastes data copied using the Copy With Axis feature into the current table.
The contents of the clipboard must be of the same dimensions as the contents of your table.
Add |
Add the contents of the clipboard to the table |
Subtract |
Subtract the contents of the clipboard from the table |
Multiply % |
Multiply the contents of the table by the clipboard values as a percentage |
Multiply % ‑ Half |
Multiply the contents of the table by the clipboard values as a percentage divided in half |
Average |
Average the values between the clipboard and the table |
Pasting Histogram Data from VCM Scanner
When using tables in VCM Scanner's Graph panel properly, the Paste Special function can be used to import the learned graph data into the current table.
An example of this is building a knock retard graph and importing it into your main spark tables.
Undo Last
Undo your last action.
Undo All
Undo all actions.
Units
If there are multiple unit types available for the data in this table, this option allows you to choose the units of the displayed data.
Column Axis
Includes options to copy the labels from the column axis, edit the column axis, or change the units of the column axis.
Row Axis
Includes options to copy the labels from the row axis, edit the row axis, or change the units of the row axis.
View Inverted
Select this option to display the table as inverted (swap the X and Y axes). When a table has been inverted, the word INVERTED appears above the upper-right corner of the table.
