Parameter Colors
The colors change to indicate parameters that have changed since the last save or that differ from the same parameter in a comparison file.
Single Calibration File Open (No Compare File)
When you only have one calibration file open, parameters that have changed since the last save are displayed in a different color.
No changes have been made to either table. |
The High Octane table has changed since the last time the file was saved. |
Primary Calibration File and Compare File Open
When you have a second file open for comparison, the colors also indicate parameters that differ from the corresponding parameters in the compare file.
The values of these parameters in the primary file match the values in the compare file. No changes have been made to either parameter since this last save. |
The values of these parameters in the primary file match the values in the compare file. The High Octane table has changed since the last time it was saved to file. |
Comparable fields do not exist in the compare file. Neither field has been changed since the last save. |
Comparable fields do not exist in the compare file. The High Octane table has changed since the last save. |
The values of these parameters are different in the primary file than they are in the compare file. No changes have been made to either table since the last save. |
The values of these parameters are different in the primary file than they are in the compare file. The High Octane table has been changed since the last time it was saved to file. |
