Shift Ignition Cut
This module controls the amount of additional ignition cut applied when shifting gears.
The amount of ignition cut requested is output by this module as Gear Shift Ignition Retard. This is sent to the Ignition Target Demand module, where it is combined the with other cuts and retards and applied to the base ignition angle in order to determine the final ignition angle demand sent to the spark plugs.
