Launch Control
Launch control is a feature that allows the driver to launch from a standstill while the ECU carefully limits power in order to reduce wheel spin.
To use the feature, Launch Control Enabled must be set to YES. Once the feature is enabled, launch control will attempt to limit power when all of the following conditions are met:
Throttle position is not below Launch Control Enable Throttle Position Minimum.
Vehicle speed is not above Launch Control Enable Vehicle Speed Maximum.
Engine Speed is above Launch Control Engine Speed Threshold.
Once activated, the feature limits power using the method(s) specified in Launch Control Cut Mode.
The feature will be deactivated (stop trying to limit power) when any of the following conditions are met:
Throttle position is below Launch Control Enable Throttle Position Minimum.
Vehicle speed is above Launch Control Enable Vehicle Speed Maximum.
Engine Speed is below Launch Control Engine Speed Threshold minus Launch Control Engine Speed Hysteresis.
