Flood Clear
Flood clear is a feature that clears the fuel from a flooded engine. To do this, the ECU switches off the injectors and allows the engine to crank, but not run.
To use this feature, the driver must:
| 1. | Press the accelerator pedal enough to open the throttle past the position specified in Flood Clear Throttle Position Threshold. |
| 2. | Crank the engine. This will cause the engine to enter flood clear mode. |
| 3. | When the flooding has cleared, the driver backs off the acceleration pedal by the amount specified in Flood Clear Throttle Position Threshold Hysteresis. This will exit flood clear mode and allow the engine to run normally. |
