Page 1 of 5 12345 LastLast
Results 1 to 20 of 82
Thread: Configuration & Histogram Repository
    Nov 2005
    Someplace high in the Himalayas
    770
    Here is my configuration for an LS2 A4.
    Its setup to calculate torque - Torque.hst
    Has a user pid for an LM-1 which is set to 0-5v, 10-18 afr. You will just need to set your offset.
    I would also upload an excel sheet for an ls2 ve, but its too big at 350k.
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Apr 2003
    Almost 2000 feet.
    7,876
    All right guys, here's the Gen-IV Config & Histogram section!
    2005+ Gen IV's only! No LS1/LS6/LQx/LR4/LMx/L59 please!
    As many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
    Year
    Make
    Model
    OS
    Vin
    What the config is for? Idle tuning, SD tuning, MAF tuning, General
    If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
    If you have custom histograms you'd like to post as well feel free. Same info is needed.
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    The .cfg (configuration files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2 Directory
    The .hst (histogram files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
    Here's an 05-LS2 (any) config for tuning with either STFT only (LTFT disabled) or with AFR Error. Enjoy!
    Always Support Our Troops!
    Feb 2006
    Warner Robins, GA
    202
    EC, I tried your cfg, and ilooks like this is good to take care of VE % Maf Tuning. I guess you recommend adjusting your VE table with STFT rather then LTFT right? Is there a reason behind that?
    Now that I have the MAF hi/lo values in the histograms what do I need to do in order to apply them to the tune?
    Also what's that KR under EIO Output for?
    2005 Pontiac GTO LS2
    MY FQUICK - http://www.fquick.com/cyclone_chris
    Mods:
    K&N Intake | 18" Staggered TSW Thruxton Setup | Toyo T1-R Tires | Billet Products Short Shifter | Kooks 1-3/4" LT Catted headers | NGK TR55 | Ported Stock Intake Manifold | Corsa Sport Exhaust | Polished T/B | FlowTech Streetsweeper V2 Cam | SLP UD Pulley | 160 Thermostat | LS7 Clutch | 39# Ford Blue Giant Injectors | Scorpion Roller Rockers |
    445 RWHP/413 RWTQ
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    just make sure your logging maf in hz otherwise the maf histo wont work.
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's an 06 LS2/LS7 config. Also works on 07's.
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's a "generic" E38/E67 V8 config and a couple histos.
    I don't have the Main Spark Calc Burst Knock in the histo's on the E38/E67 config but you can load it easily enough.
    Also a couple custom PID's
    Apr 2003
    Almost 2000 feet.
    7,876
    Custom PID for the above..
    Nov 2005
    770
    How do you get the HP histo to work? I get Unsupported parameters on both the Plot value, and the x and y axis?
    Also, can someone upload the MPG histogram and cfg? I can't figure out how to get it to work on an LS2.
    Stock:13.36@104
    Apr 2003
    Almost 2000 feet.
    7,876
    You need the custom PID added to your config as well.
    Nov 2005
    770
    Still not sure what I need to do.
    Stock:13.36@104
    Apr 2003
    Almost 2000 feet.
    7,876
    Read the help file about custom PID's. Then copy the text I placed in the TXT file above.
    EG:
    EQ Ratio Error is the name of the custom PID
    EQ Err is the abbreviation for the chart
    Pick % as the value
    100*((([SENS.120]/14.7)-[PID.68])/[PID.68]) is the formula.
    Advanced Tuner flea's Avatar
    Aug 2006
    Illinois
    242
    LS2 Idle air & PLX AFR
    LS2 Idle Air (filter <2.5 mph)
    PLX AFR vs RPM vs ECT
    Flea
    2006 GTO
    Kooks LTs, NGK WB
    12.96 @109.12
    Aug 2006
    Illinois
    242
    GMVE PID & Histo
    Created for LS2 GTOs
    [SENS.41]: g/cyl
    [PID.2126]: Manifold air temp
    [PID.11.MET]: MAP (kPa)
    ([SENS.41] * [PID.2126])/ ([PID.11.MET] * 0.001)
    Flea
    2006 GTO
    Kooks LTs, NGK WB
    12.96 @109.12
    Apr 2003
    Almost 2000 feet.
    7,876
    2008 E38/E67 configs
    This config & histograms should work on most 2008+ vehicles with the E38 or E67 PCM. Should even work on V6 engines too but it's untested on the V6's.
    Apr 2003
    Almost 2000 feet.
    7,876
    More Histograms
    Here are more histograms that go with the 08's.
    Alright, I've got to ask. Whats the idea behind the EQ Ratio Error?
    Quote Originally Posted by EC_Tune
    Do I need these to log LTFT & STFT on my '08 C6?
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by Harlech
    no
    is there CFG file for the E38 and E40 metric & imperial use to be hear and i cant find them .can some one post them please .
    May 2007
    489
    Ok does anyone have a config file and a histogram that will work with a 2009 G8 GXP.
    None of the ones in this thread really work, most of them will log the main spark adv and KR but that is all that works once I try to watch the run.
    I would like one that logs:
    Main Adv
    KR
    IAT temps
    STFT
    LTFT
    I guess any others that would be recommended would nice. I am trying to log some runs with the car to nail down some WOT issues that happen as soon as you stab the throttle.
