I'm not familiar with FI tunes at all, and i'm trying to help somebody with his setup, and correlate possible engine failure with a bad tune.
The car is a 2008 G8GT, Procharger D1SC 9PSI 2 core intercooler, 80# FIC injectors, Pacesetters Longtube headers, catless with flow master mufflers. tune attached. the car was running like crap just after SC install and tune, owner felt the car didn't have a lot more power after the sc install and tune. LTFT's in the 20% area, car was throwing P0171 and P0172 errors.
The tuner didn't adjust SD at all, didn't turn it off either to tune her. stoich ratio seemed to be double, and nothing else seems to have changed in the injector section, only the short pulse limit was lowered. Timing lowered, and a couple of other little BS. Lol is this how people tune FI this days with bigger injectors ? WTF ?
Can somebody explain the AFR trick ? why would the tuner attempted to increase stoich AFR like that, is this some sort of new trick for bigger injectors, or just one of those "opps, i just splashed my fingers in the keyboard, give me $500 for the job" type of thing?
The car was running so bad after the SC and tune, the owner had the engine checked, cylinder 6 has a blown piston and spark plugs in Cylinder 6 and 4 have exploded. Compression in 4 is 170 and 0 in 6
