As the title says, I just installed a Whipple on an otherwise stock LS3 manual trans 2010 Camaro.
And, Im analyzing the logs, and noticed a somewhat serious problem during shifts related to the reaction of the MAP sensor and it delaying PE mode/additional fuel.
Attached is a picture, but what happens is if I shift, then go WOT quickly, then the Airflow spikes up instantly which is good, but the MAP sensor reaction time is slower, and even after it enables PE fueling, there is a delay before injector pulsewidths react... this causes a delay in PE fuel, which then causes lean fueling and lots of knock.
This all happens very fast, the delay looks like about 0.25 seconds long, but is enough time to run lean and cause knock, which is very bad for stock pistons.
My last car was pure SD mode, 1996 TA with procharger 100% reliant off the MAP sensor for fueling and never had this problem as it reacted very fast.
Is there some type of smoothing or delay built into the MAP sensor reading, or something else I can do to speed up it's response time? The MAF sensor reacts instantly, and I suppose I could try one or all of the following to resolve this?:
1) increase fueling in this hz range but then I'd have to 0 out the PE fuel, which in the end would cause all kinds of other problems I would think.
2) Enter WOT slower, but that can be tricky
3) Would it be possible to delay the reaction of the Throttle blade just a bit by software so no matter how fast I mat the throttle, it's opening rate is slowed just a bit to take care of this problem?
4) increase the about of burst knock during very rapid WOT throttle transitions without affecting normal (non-WOT shifting) burst knock amounts? If I find a way to add up to 10 degrees of Burst Knock timing reduction in this type of throttle change then this problem would likely not exist.
