a certain company tuned a buddy of mines car, and after logging a wot pass im registering 109-110% duty cycle on a bolton 99 z28(longtubes,gears, catback, lid, and maf) with stock injectors, and a racetronix pump. What is out of wack?
618/618 motor
906/862 spray
Omg...........
EFI specialist
email=[email protected]
that bad huh guys, treat me like a newbie i know the bare basics, what am i looking at? Oh and I appreciate all the help!
Ha. Don't be bashful... Share who did that!
http://www.dsxtuning.com
Just say no to bull s***.
Well it should be a curve, not the Rockies.
That table is the maf transfer table, defines what frequency correlates to what airflow value. As stated it should be a smooth curve. This one ramps up an unrealistic amount then falls back to stock values.
So who done it?
Sent you a pm with your answer
Tell me too!
FYI, if the car is seeing over 100% duty cycle, that means the injectors are done. If it isn't rich, then the tune can be as hacked apart as possible... the duty cycle PID still remains true.
could be the tuner is compensating for low fp...
Me too please! They just hammered the balls off this tune. Hey edcmat-l1, can we add this into the shitty tune repository?
618/618 motor
906/862 spray
Would an over compensated Maf curve "cause" a higher than actual injec. duty cycle?
im aware that when i see an idc of over 100 percent they are done, that is what initially made me post in this section because i knew something was off, just did not know what in particular. The car does NOT have a cam, just your basic bolt on z28. The car has a racetronics pump in it so I don't believe there is a "Fuel Delivery Problem"
Ok.
So, if the car has an upgraded pump and plenty of injector, what else would cause the injectors to read high. Is the stock Injector rate modified?
ok so my next question is, how do I fix this, because I surely do not want the car going back there? I guess what I'm tring to say is, does anybody have a tune thats for a bolt on z28 that I can work with?
Ok. Now I'm confused. My original question was just that. It would seem that the Maf was over compensated or the values were just to high for what the engine truly needs thus scewing the injector duty cycle. Just that, the pcm thinks that there is more coming then it really is thus increasing the amount of fuel to hit the desired afr.
Well, the car has a new maf right? More than likely it was dialed in incorrectly. I would start there unless a more experience member on here has a better approach. You'll need a wideband to get the proper information to scale back down the maf values.
