I have a quick about this setting. On the 2.0 lsj cobalt ecu's there is a setting called "Maximum knock retard". What exactly is this setting and how does it work.
For example lets say you have it set at 3 degrees of kr at wot at 5k rpms. If it hits 3 degrees, what happens? Does the car pull timing or what? I don't know much about it, but it seems like having it set at 8 degrees at wot is a bit high.
I am just going through all of my "safety" parameters and making sure its setup the way I want. Thanks for the help guys.
PS: I have zero knock retard on e85 no matter what degree of timing I run, but I still want to have this table setup properly and know/learn how it works.
