I'm quite sure there isn't anything wrong (provided you're not dividing by 1000 anymore based on Ford Racing data). Look at the factory values, they are also listed in seconds in HPT now. I wish they would have kept the prior method, as this is how Ford displays them in the PowerPC. It's confusing with all the softwares displaying different.
Correct, for the most part. It's not always perfect, and you may need to modify the MAF transfer some.
However, I tend to believe most of your issue is actually the PW Minimum scalar, and not being able to go over 1.0 sec. That will completely jack the tuning altogether. Just for shits/giggles, I'm going to give you a different set of 42# injector data. It's still for the exact same "green top" Ford injector, but this data comes directly from Ford, not Ford Racing. This is what Ford used in the Lightnings, FYI. Keep in mind, Lightnings had a mechanical returnless fuel system, and not a variable rate ERFS (electronic returnless fuel system), so Ford didn't give the injector data for the flow rate multipliers. However, the data still applies for 39.xx psi, and this will serve as a test for idle to see if your fuel comes inline.
Flow Rate Low: 48.9612579345702
Flow Rate High: 40.68031311035172
Breakpoint: 0.0000194
PW Minimum: 0.400543212890625
Offset vs. Voltage:
Code:
0 4.647460938
0 4.647460938
0 4.647460938
6 4.647460938
8 2.118164063
10 1.396484375
11 1.197265625
12 1.03125
13 0.903320313
14 0.786132813
15 0.71484375
15.99975586 0.71484375
Also, one another thing, didn't you say this car has the GT500 fuel pump assembly and dual FPDM setup (basically the Ford Racing setup)? If so, your PID values for that arrangement is wrong, and that can also cause fuel delivery issues. Change your PID values to such:
Derivative: 0.0000
Integral: 0.0549999997019768
Proportional: 0.0599999986588955
Also, update your FPVT (fuel pump voltage table, aka "Voltage vs. Flow vs. Pressure") to the following:
Code:
5.12142 5.15227 5.29316 5.52084 5.95558 6.85844 7.81190 8.82504 10.28930
6.10597 6.13709 6.27926 6.50924 6.94913 7.86634 8.84151 9.63743 11.17536
6.54669 6.57798 6.72093 6.95228 7.39525 8.32108 9.30927 10.37487 11.95700
7.57505 7.60671 7.75147 7.98603 8.43622 9.38214 10.40073 11.51222 13.19748
7.94233 7.97412 8.11952 8.35523 8.80799 9.76109 10.79053 11.91842 13.64051
Flow Axis:
Code:
0.045 0.000
0.100 1.000
0.350 2.000
0.750 3.000
1.500 4.000
3.000 5.000
4.500 6.000
6.000 7.000
8.000 8.000
Pressure Axis:
Code:
25.000 0.000
35.000 1.000
41.000 2.000
55.000 3.000
60.000 4.000
60.000 4.000
60.000 4.000
You still won't have the ability to change the Max Inferred MAP Value to at least 64, since HPT still hasn't added that parameter in (I can't stress how important this is, so as to allow the pcm to recognize boost).
