so buddy has a 2004 Grand Prix Comp G and since i read on another forum that is more 3800 based the 3.4 pulley he has recently installed is maxing out the stock fuel injectors since his WOT is stuttering like it's choking and not getting the fuel it needs.... he has 42.5 lb lucas injectors and wanting to install them but obviously i'm the guy that needs to update his tune for this...
running the latest HPT beta 2.23.321 so i have access to Offset vs Volts, Offset vs PW vs VAC, Flow Rate vs KPA, Skew vs Cylinder for injector tables.... i know i have to change the flow rate vs kpa for the injector table but just wanted to know what other tables i'd have to change because i wasn't sure if i'd have to modify the offset vs pw vs vac table or if any other or not since i know you don't just change one table to make it work and go on about your day and think it's running ok... i'm guessing i'd have to modify the maf slightly to compensate for it as well.... thanks in advance! current tune is attached below and this is the only specs i can find for these injectors
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Static Flow Rate: 48.83 lb/hr @ 58.0PSI (300kPa) or 370gm/min
Coil Resistance: 15.9 Ohms / High Impedance / High-Z
