I took the car out to the track last night and the transmission was acting up the whole night and i have no idea why.
First pass of the night I pulled second gear only to watch the A/F on the wide band to make sure everything looked good, stayed richer than 11.8:1 on the wideband the whole time, so all was good and decided to come around and make a second pass. Put the car in manual first launched, the car immediately shifted to second upon launch, I was going no faster than 10-15 MPH as this point. Came around made a second pass in OD to see what would happen, same result.
I went in to the tune and reset all the tables to stock with the exception of full throttle shift RPM and Full throttle enable %. Made another pass, (as seen in the log) put the car in manual low and the car held first a little longer, still shifted to 2nd on its own earlier than 7000 RPM.
Came around made another pass, this one at frame 2240, with the car again in manual 1st, and the transmission shifted to second early, then back to first, then back to second, then back to first, and then to second and proceeded to stay in second.
Im running a 5K RPM non lock-up converter and a Performabuilt Level II transmission.
Any ideas? i have never experienced anything like this before.
