Results 1 to 6 of 6
Thread: Antifreeze & o2 Sensor Damage-Cracked Heads
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    I have heard that burning antifreeze will damage o2 sensors.
    Problem = bad gas mpg after heads replaced.
    We have a reg cab 04 Silverado w/5.3 that the water pump went out on, got hot and the heads cracked.
    They were a small enough cracks the antifreeze would consume at a quart a day or so. No smoke but stinky.
    This went on for weeks while while we fought with the extended warranty Co for coverage. Long story but we got them to cover it.
    The o2 sensors were not considered by the dealer for I'm sure.
    Now the truck gets a crappy 12 mpg highway.
    Any truth to the o2 sensors & antifreeze possible damaging thing? A novice HPTuners owner I would like to ask what, if I can scan and log and tell by the numbers. Would some trims look really off?
    We need help finding the gas guzzling problem.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Log fuel trims and o2 mV and see. I could see it causing issues.
    Sulski Performance Tuning
    Feb 2009
    1,931
    Log the o2 sensors as mentioned, but based on the descripitioin they are most likely shot. Also, going through that amount of coolant for that long, you may have to check out the cat's. First confirm primary o2s and change if required. If milage still has not improved, log secondary o2s and install pressure gauge in exhuast in front of cat. If gets this far, post or pm me and I will give you more detailed instructions. You should also inform the shop foreman at the dealership of the problem before the dsm closes your case to avoid another deductable, assuming this was a recent repair. My 2 cents worth.
    Jun 2009
    N. GA
    530
    Quote Originally Posted by mecanicman View Post
    Thank You Both,
    As for the pre cat pressure gauge? What kind of range or reading am I looking for? Cats are factory warranted for a long time I believe. I hope.
    Feb 2009
    1,931
    a spark plug and air fitting can be used to make a pressure bung. I use a vacume gauge that can also read pressure. You should not have any appreciable pressure other then a slight blip when rpms are increased quickly.
    Only worry about this after you have ruled out or replace primary 02 sensors.
    Feb 2007
    Calgary
    155
    Quote Originally Posted by 2therock View Post
    Moisture kills the heater in the sensor
