Yes, there is a CLEAR victor here!
Mods:
Halltech KB Stinger
NW 102mm TB
FAST LSXR (untouched)
RPM (Charlie) Ported/Polished LS7 Heads
Lethal Z Cam (2nd Gen)
American Racing Headers w/ High Flow Cats
Factory Catback
As for the TB, it tuned out perfectly. The ETC Area Scalar I calculated worked perfectly.
Also, this is a direct 100% MAF tune (SD calculations are disabled at anything over 0 rpms). I do NOT rape the PE or IFR tables whatsoever. The MAF transfer is perfectly dialed in from 0 Hz to max Hz. His tunes have always been 100% MAF only, and I proved to myself last night that installing this intake will NOT require much of any, if any at all, modifications to the MAF transfer. His AFR deviated less than 0.0 to 0.2 AFR throughout the entire curve, which is typical error %. Those who are having to modify the AFR after installing this intake apparently do not have their MAF and/or SD calculations right (or injector calibration data set properly, if they changed injectors).
