Well I got the car out on the road and have most of the cruising VE table set. I decided to bring on the boost and the scanner will not log over 105 kpa. I set up the table as described below in the help file, and the MAP 3 bar shows nothing. It is a known good 3 bar map sensor.
With the Default Imperial, at least I get a reading. Maybe I have a setting wrong, please look them over and see if there is anything obvious that I am missing. Thanks18. (This step for 2bar and 3bar enhancement only) Open VCM Scanner and connect to the vehicle. Open the Table display (Scan -> Table Display). Right-click the "Manifold Air Pressure (SAE)" PID and select "Delete". This removes the existing 1 bar PID from the table, if you don't do this the histogram will not function correctly.
19. (This step for 1/2/3 bar Speed Density enhancements only) Right-click the "Mass Air Flow(SAE)" PID and select "Delete". This removes the existing MAF PID, if you don't do this the histogram will not function correctly.
20. (This step for 2bar and 3bar enhancement only) Right-click again on the table display cell and select "Insert", go to the Engine -> Airflow section and choose either the "Manifold Air Pressure - 2 bar" or "Manifold Air Pressure - 3 bar" PID, double-click to insert it into the table.
21. (This step for 2bar and 3bar enhancement only) Save the new scanner configuration using File -> Save Config.
22. You are now ready to tune using your new enhanced PCM.
The Test config is setup as per the help file along with a short Test scan to show the problem. Test A is a short scan using the Default config and at least showing a reading of 105 kpa.
