HP Tuners Bulletin Board
Go Back   HP Tuners Bulletin Board > Tuning > GM L4, I5, I6 Engine Tuning
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools
Old 03-25-2009, 07:14 PM   #1
black06g85
black06g85's Avatar
Send a message via AIM to black06g85
09 cobalt ss/tc using stock boost control on external gate
anyone have any experience with this. I've been playing with the airload tables and am slowly getting it where I like it. Just need to keep the wastegate closed at lower rpms, any tips?
__________________
mods=
turbonetics HiFi 60-1 ball bearing t3/t04E
Hahn Racecraft Intake manifold
Hahn Racecraft FMIC 4.5" core
custom hot and cold side hard piping
79lb/hr injectors
vulcan equal length tubular manifold
3" turbo back
TiAl 38mm wastegate
newly built motor, more to come soon
black06g85 is offline
Old 03-26-2009, 06:18 PM   #2
black06g85
black06g85's Avatar
no one, guess we're going MBC then.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Old 03-27-2009, 09:44 AM   #3
Baldturbofreak.com
Send a message via AIM to Baldturbofreak.com
Run an 8psi spring in the gate.
Set the airmass as per stock. At least the shape anyway. you can make small overall boost level changes here but make sure that the shape remains the same or you'll have overboost issues/wildly changing boost.
Then use max air torque and cater it to your turbo's charicteristics.
No boost below 4K? better make your Max air torque reflect that or you'll get an underboost code.
Slight overboost at high rpm? trim it with the max air torque table.
Biggest thing is to make sure you run a 8psi sprign as per factory.
__________________
Me love boost long time.
Baldturbofreak.com is offline
Location: Honeoye,Ny. Boondox son. Shoot guns out my back door. noone cares.
Old 03-29-2009, 06:49 PM   #4
black06g85
black06g85's Avatar
thanks man, yeah I need to try that I guess. Car is on a 8lb spring right now. Too bad I didn't see this earlier had the car on the dyno this afternoon and it was pissing me off lol. Kept closing the Throttle up top though, can't figure that one out as of yet.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Old 03-29-2009, 07:49 PM   #5
Baldturbofreak.com
It got a 38mm or a 44?
__________________
Old 03-30-2009, 05:19 AM   #6
black06g85
black06g85's Avatar
38mm Turbosmart gate.
was going to an absolute TPS of 69% above 6300 rpm. No matter what I changed it still did the same shit.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Old 03-30-2009, 07:37 AM   #7
Baldturbofreak.com
Post some logs. I'll have a peep. maybe a torque table was missed?
Or the gate is having difficulty controlling boost on the top end and the pcm is closing the throttle to prevent overshoot?
__________________
Old 03-30-2009, 05:48 PM   #8
black06g85
black06g85's Avatar
I think I screwed up something in the tune possibly. I'm going to start from scratch this week. Load was reading weird, it was rising then dropping off after 5700rpm down to @72% it was also a little choppy. I dunno, I'm new to the LNF PCM. I'll get the hang of this animal though.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Old 03-30-2009, 05:48 PM   #9
black06g85
black06g85's Avatar
btw I could email it to you as I'm not posting it up on here.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Old 04-01-2009, 05:33 AM   #10
black06g85
black06g85's Avatar
Thanks for the advice, swapped out to a dual stage MBC last night, re tuned. 22 psi, car is an animal. Can't wait to get it back on the dyno. No more throttle closing which is fantastic.
__________________
mods=
79lb/hr injectors
3" turbo back
TiAl 38mm wastegate
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.12
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
