| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#61 | |
im interested in fuel cause if we can get extra time or up the pressure to spray more like possibly run a gt3076r at 28 without to much of a problem im so down for ordering the kit as soon as our uprgrade is released lol
jizz in my pantss hahaha run your 80 psi and cap to 58 haha = LNF TRACTOR EXHAUST STACKS 8"
__________________
PERFORMANCE MOTORWERKS CA 2008 cobalt ss/tc, fully ported cylinder head, ported intake/exhaust manifolds, ported up pipe, ported one of a kind k04+ btf turbo, full ferrea vale assemblies(ferrea titanium valves, springs, retainers) super stealth
#62 | |
Does big boost make you hoewnay baby YeaH! Lol
Fuel tabels are going to be a big plus, yet still a limit until big injectors are availible. Until then a second rail will do nicely.
__________________
Me love boost long time. |
Location: Honeoye,Ny. Boondox son. Shoot guns out my back door. noone cares.
#63 | |
i want to see a full tilt duramax cobalt ss with exhaust stacks out the rear window haha just cuz
or the rear cornerside window triangle exit would be kinda cool too
__________________
#64 | |
chris/bill.....any updates on this?
512kpa on LNF ecm cracked yet! ![]()
__________________
BTF GT3582R Turbo/AEM Methanol Injection/CryO2 Intercooler Spray/SPEC 3+ Clutch 403whp & 382 ft-lb CAR SPECS and PHOTOS: www.carsponsors.com/420576 SPONSORED BY: specclutch.com statusracing.com supertechperformance.com k1technologies.com wiseco.com v-leds.com tceperformanceproducts.com Magazine Feature: http://www.saturn360online.com/viewMagazine.aspx#/23/ |
#65 | |
was running 25psi the other night on a gt3076 car we did. she liked it lol.
__________________
mods= turbonetics HiFi 60-1 ball bearing t3/t04E Hahn Racecraft Intake manifold Hahn Racecraft FMIC 4.5" core custom hot and cold side hard piping 79lb/hr injectors vulcan equal length tubular manifold 3" turbo back TiAl 38mm wastegate newly built motor, more to come soon |
#66 | |
Yup thats in a delicous spot in the map. Up to 28psi is great.
__________________
#67 | |
Junior Tuner
subscribing cuz I'm jones'n
#68 | |
Bueller?
__________________
#69 | |
HP Tuners Support
(foff667) |
Patience, Rome wasn't built in a day
![]() We're working on it as well as several other projects at the moment.
__________________
#70 | |
chicka chicka!! chicka chicka!! dew bow bow .... ohhhhhh yeaaaaa!
i think we should streamline lnf breakdown 8D ... wishing on the non existent stars
__________________
#71 | |
Junior Tuner
So i'm guessing that the 512kpa is good because those with the GMPP mod will use it? Will it help the Stock turbo make more power?
__________________
(Jeff's 2008 HHR SS/TC), 5 speed, Black / Black) 15.xx @ 99.4 MPH stock New Mods: GM Stage 1 Kit, K&N Filter, Hahn Catted DP, Crazysteve IC, DEJON IC Piping ( 98 Z28 A4) Sold
#72 | |
No and no. 512kpa means we can add a new turbo and go above the current boost limits. Our current turbo can only blip up to those levels for short periods of time anyways. This would not require the GMPP tune.
#73 | |
The 512kpa is good becasue it means the archetecture of the PCM can handle BIG ass power/pressure. It comprehends 120lbs/min (about 1300hp in a well thought out 4 banger) and 58psi absolute. That's what we're excited about, no factory PCM to date operates with this kind of range. Gonna be nuts in a few years when this PCM is fully cracked.
It Most definitly will help out power even with the stock turbo. Jsut not in the high rpm range.
__________________
#74 | |
#75 | |
Indeed, cause My frankenstein setup isnt going on there until....
__________________
#76 | ||
Quote:
#77 | |
its out of the sensors range but not out of the computers reading capabilities
__________________
#78 | |
The stock turbocharger itself will not run that high of boost in the upper RPMs.
Still, 30PSI from 3000-4500 rpm would be nice until higher flow injectors come out. Unfortunately it will drop back to ~ 19-20 PSI by 6300rpm
__________________
2004 Ecotec Cavalier - full bolt-ons, HP tuned to 7000RPM 2008 Solstice GXP - HP tuned to 21PSI (30 lbs/min VE Airflow ), AIS stage 1 water/methanol injection, Hahn Racecraft Intercooler
#79 | |
#80 | |
HP Tuners Support
(foff667) |
Stock turbo would probably run out of steam at any decent rpm well before then...any additional tables we add regarding this or limits we change will probably only help those running larger turbo's meant to spool well past 22psi.
__________________
| Thread Tools | |
