Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: 2009 ZR1 Injector Values Inside
    Jun 2005
    Southern FL
    2,044
    Here's the injector values (attached in Excel format) from the 2009 ZR1, in case someone wants to use these injectors in their GM.
    FYI, in the IFR table, GM has the 58 psi (aka 400 kPa) column listed at 56.43037 #/hr, which is basically the size of the injector.
    Regards,
    James
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,023
    Excellent reference info, James. Did you get a chance to look at the injectors and note the part number?
    Once these become available, they can and should become one of the first choices for forced induction LSx street cars.
    Very Good Info!
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Quote Originally Posted by eficalibrator View Post
    I hear that! AND we have all the correct injector data to go with it!
    Howard
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Feb 2006
    WPB, FL
    372
    Hell yeah!!!! I just started a thread on LS1tech asking for this very information. I will link it.
    98 Z28 370 LQ9 w/ TH350, FTI 4800 Stall, OLSD, NW90 TB, 80# Motron Inj, AFR 225's, 231/231 .624/.624 114, Mamofied FAST 90 Intake, PT88 Front Mount w/ 4" DP dumped before the Strange S60 w/ a 3.73 gear
    Jun 2005
    Southern FL
    2,044
    Quote Originally Posted by LosLS2 View Post
    And link us to that thread!
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    LS9 and LSA use GM pn 12598646 and AC Delco pn 217-3350.
    13* spray cone angle
    391 g/min flow rate @ 400kPa
    51.72 lb/hr @ 58 PSI
    This is per the blueprint.
    GMSPO has stock but not many. $90.26 list price each or cut that in half for dealer cost.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Dec 2008
    2
    $46.94 from GM Parts Direct.
    And I might just need new injectors for my LS1..
    Jun 2005
    Southern FL
    2,044
    Quote Originally Posted by 69lt1bird View Post
    That completely contradicts GM's IFR values for the ZR1 calibration. Go figure!
    Thanks for putting up the part #s! Does the blueprint show the injector physical size specs in regards to external dimensions? It would be nice to have those, along with say the LS7 injector physical size specs.
    Jul 2006
    403
    Wonder if the offset vals would push me more towards accuracy with these SD injectors -
    http://www.racetronix.com/M145FM2.html
    Static Flow Rate @ 58.0PSI (400kPa): 53.7 lb/hr = 6.77g/s = 552cc/min (+/-3%)
    Do you think that they flow tested using n-Heptane like racetronix? Are the values converted from n-Heptane?
    2006 Trailblazer SS - Stalled, Cammed, Tuned, Turbo'd, Built, and Stroked.
    Runs on cash, blood, sweat, and tears...... and 93 octane.
    2007 Cadillac STS-V - Stock.
    Jun 2005
    Southern FL
    2,044
    Nah, no way they are the same in regards to values.
    James,
    Do you have a copy of a stock bin from a ZR1? I would to have a look at it.
    Regards,
    Brian Turner
    Dyno Tune Motorsports
    Dyno Tuning and Remote Tuning For Ford - GM - Chrysler Vehicles
    Click Here For Dyno Tune Motorsports
    1988 Ford Mustang GT INCON Systems TT
    331 Cubic Inches - Corn - 808 RWHP 918 RWTQ
    Nov 2008
    2
    Quote Originally Posted by Blades View Post
    Quote Originally Posted by RWTD View Post
    I thought the samething when i saw the flow rate as compared to the Siemens FI11351 or 04891574AD injectors. Has anyone had these flow tested or have good injector data for these injectors use on a GM LS2 or other motor. RWTD just curious what about the ZR1 data says they are not similar at all?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    So if these were put in a Z06, what's the proper way to edit the IFR vs. Manifold Vacuum table? For manifold vacuum of 0 (dead center in the table), I have 41.74 lb/hr. Would I take the ratio of the ZR1 injector at 58psi to the LS7 injector at 0 manifold vacuum, and multiply every value in the table by that?
    Basically, 56.43047/41.74 = about 1.35195. So, would I multiply my whole IFR vs. kPa table by 1.35195?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2005
    Southern FL
    2,044
    DSteck, no, don't ratio like that. Input them in properly. Lemme explain:
    You have an '06, so your values are listed in kPa VAC, so you'll just need to convert them over to kPa Pressure Delta. Here, this should help:
    Code:
    VAC     80	70	60	50	40	30	20	10	0	-10	-20	-30	-40	-50	-60	-70	-80
    RAP     480	470	460	450	440	430	420	410	400	390	380	370	360	350	340	330	320
    You can easily do some math to make it exactly precise to match the factory values up. I'll work to build you a table later when I have some time (I can do it pretty quickly).
    Mar 2008
    St. Louis, MO
    4,859
    I understand now. I'll have to convert to kPa, and then interpolate since the ZR1 values don't line up with my '06 Z06 values. Thank you, good sir!
    Jun 2005
    Southern FL
    2,044
    Yeuppers, you got it! You may not even have to use the interpolate function of HPT, but rather get it exactly precise. However, very minor variations won't really matter much, as you know. FYI, 1 psi = 6.894757 kPa.
    Also, I'll add in the Metric labels up in my xls file above, as I only have the Imperial ones currently. That should help to make it a lil easier.
    Mar 2008
    St. Louis, MO
    4,859
    To me, it'd be easier to just use Excel, fit a trendline, and use that equation to generate values at each cell. I can't imagine the error would be enough to make or break the calibration. Now if I can only convince my buddy to buy my stock LS7 injectors to offset the cost a bit...
    I assume the LS9 injectors are the same physical size as the LS7 ones... can anyone confirm?
    Mar 2006
    Detroit
    1,023
    New flow IFR_2 at Pressure #2 (P_2) can be solved using the Bernoulli equation based on a known reference flow (IFR_1) at a reference pressure (P_1), usually 400kPa or 58psi for GM vehicles:
    IFR_2 = IFR_1 * SQRT[ (P_2/P_1) ]
    Aug 2008
    28
    The ZR1 offset values worked perfectly on my modified 52 lb/hr Bosch LS2 injectors from Fuel Injector Connection. I tried the stock LS2 offset, but they were still too low, and it only had accurate values where the stock engine would operate. I like the ZR1 table because it has proper numbers in the "boost" area, so if you're running a 2 bar MAP, you will still have accurate injector offsets while in boost.
    RWTD, thanks for the data...it made tuning my injectors a breeze!
    '08 TBSS - ProCharged | '09 G8 GT
