Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: 6L80E, holding tranny in drive on the dyno
    What's the "trick" for keeping the A6 in gear on the dyno. Even using the paddle shifts won't leave the car in gear.
    Thanks in advance for any advice.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    You must modify your calibration to allow you to lock it into gear using vcm controls as most calibrations do not allow it over a specific RPM and MPH
    I have asked this question several tmes for the 07 Sierra's and certain Trailblazer SS's and it wouldn't work. Has this been rectified now.
    Advanced Tuner midevil1's Avatar
    Feb 2009
    TX
    365
    If you follow the screen shots that Bill posted you wont have a problem. You can hold any gear, any rpm.
    2023 Ford Edge ST
    2020 Ford F150 King Ranch 5.0
    Dec 2010
    37
    My first time messing with the A6 so forgive the stupid question. Im assuming that setting the max rpm and speed to a high setting will keep the vehicle in the gear you have manually selected and keep it from downshifting? Thanks in advance...
    Apr 2005
    Sugar Land, TX
    1,198
    This seems to work for me. I dyno in 3rd gear paddle and never shifts to 4th.
    Jun 2012
    Grand Rapids, MI
    75
    Could someone please re-host the photos? This is a worthless sticky if all the information is in photos with broken links.
    Thank you,
    Jack
    -2000 C5
    Aug 2006
    5BA8
    3,177
    The procedures mentioned are no longer needed. You can lock them in gear, and lock the converter with the VCM controls now.
    Put it in paddle mode. Shift into 4th (closest gear to 1:1). Open your VCM controls in your scanner. Go to Trans. Click 4th gear, and lock the converter.
    EFI specialist
    email=[email protected]
    I am trying to tune a 2014 Silverado but I am not able to get this to work. I have left it in Drive, I have put it in Manual but no luck getting the VCM controls to select or hold the gear, even if I try to hold the current gear that I am in.
    2014 Silverado 5.3 - New Mod Template
    Bump...
    Jan 2010
    2
    Quote Originally Posted by mm_n_p View Post
    Bump...
    Same problem here, Im emailing support sitting on the dyno so if I get a fix I will glady post it.
    Nov 2013
    11
    Did you do what is suggested in post #2?
    Nov 2013
    11
    Anybody get this to work?
    Apr 2005
    Sugar Land, TX
    1,198
    Try the Corvette shift properties and TCC tuning. Worked for my 08 Corvette on the dyno.
    Nov 2012
    2
    I just dynoed my 2014 6.2 Sierra basically following the procedure noted by Ed (except I used 3rd gear) and it worked fine.
    Jul 2014
    218
    I'm going to try it this weekend . Let me just make sure I have it right .
    I set the max rpm high , figured set it just under my rev limiter .
    Then I set the max vss and the downshift mph very high .
    Correct ?
    Oct 2012
    ca
    18
    I know this is an older thread...But how do you put it into paddle mode when the engine/trans are not in the original vehicle? The other fields where already set high. I am not able to control trans functions with the scanner at all.
    just set the down shift tables with lower speed (5mph) 3 > 2 and 4>3 ..
    Advanced Tuner WS6HUMMER's Avatar
    Feb 2006
    Pineville La. US
    771
    Once you perform these changes can you leave them in the final tune?
    99 T/A WS6, original LS1 turbo
    Dec 2015
    Miami,Fl.
    290
    If you went with these changes then yes you can.
    2023 Ford Maverick 2.0T AWD
