| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 | |
Any special consideration for e-10?
So should you tune e-10 stoich for the same as "gas" to 14.68 AFR? I am tuning my Tahoe and since its flexfuel capable it has a ethanol sensor in the tank. No matter what I did I couldn't get the AFR to read 14.7 on my wideband, all I got was 13.8.
I remembered our gas is e-10 (90% gas 10% ethanol) and after some fooling around I found the stoich table in HP tuners has a linear scale from 100% gas to 100% ethanol and low and behold e-10 was right around 13.8 AFR I set e-10 for ~ 14.6 AFR and voila! worked perfectly. After cruising for about 60 miles I noticed a 2 MPG gain on the tahoe. Searching around I've found that E-10 stoich is between 14.03 and 13.9 AFR does that mean I should set the AFR on my other cars to 14.03 as well since they don't have ethanol sensors or should I leave it at 14.68 and call it a day?
__________________
2004 Yellow GTO M6 1 of 1014 HPTP, LM1, Custom airbox, K&N Filters, CS intake, FAST Manifold, Bypassed/ported TB , TR224 112 Cam, Taylor 10.4 wires, NGK Plugs, SW LT headers, SW Custom Side Exhaust, CAGS, King springs, Hotchkis sways, Pedders & ES Bushings, DBA rotors, Hawk/Axxis pads, Stoptech lines, shiftlight, AP Sideskirts, AP rear bumper, 05 hood, SAP grilles, Hoens Stock 309.8 RWHP 330.7 RWTQ Now 375.3 RWHP 352.9 RWTQ Best ET 12.82 @108My GOAT |
#2 | |
Супер Модератор
Without the ethanol sensor (or virtual sensor like the NBS E85 trucks and such) the car/truck can not determine ethanol quantity.
__________________
Dynamic Tuning Solutions & Strictly Performance are now one! We are induction, exhaust, engine, transmission, and suspension specialists in the Los Angeles area. We do all Gen III segment swaps - email your file to EC_Tune 818-342-5693 for purchases and/or appointments sp_motorsports@hotmail.com 7444 Reseda Blvd. Suite K Reseda, CA 91335 Always Support Our Troops!
#3 | ||
Quote:
__________________
#4 | |
Yes, if the gas has significant ethanol content and the vehicle does not have a fuel composition sensor, you should change the stoich point in the ECU calibration.
Stock vehicles get away with it because the shift between E0 and E10 is inside of the allowable fuel trim limits for closed loop. If you plan to spend more time operating at the outer edges of the engine's performance envelope, you want the ECU to know the proper stoich ratio. Otherwise, "10% enrichment" may no longer really be 10% enrichment.
__________________
~Greg EFI Tuning Classes <--- check my website for upcoming training class dates! Can't make it to a class? Check out this DVD and learn from your own garage! Check out my books on Amazon.com here and learn from your couch. |
#5 | ||
Quote:
![]() Also can you define significant ethanol content? Should I be concerned about tuning an LS1 based engine (GTO) to 14.68 and running e-10 in it? What I may do is pick a median AFR say 14.2 or so and leave it be
__________________
2004 Yellow GTO M6 1 of 1014 HPTP, LM1, Custom airbox, K&N Filters, CS intake, FAST Manifold, Bypassed/ported TB , TR224 112 Cam, Taylor 10.4 wires, NGK Plugs, SW LT headers, SW Custom Side Exhaust, CAGS, King springs, Hotchkis sways, Pedders & ES Bushings, DBA rotors, Hawk/Axxis pads, Stoptech lines, shiftlight, AP Sideskirts, AP rear bumper, 05 hood, SAP grilles, Hoens Stock 309.8 RWHP 330.7 RWTQ Now 375.3 RWHP 352.9 RWTQ Best ET 12.82 @108My GOAT Last edited by radkon : 03-28-2008 at 02:07 PM. |
#6 | ||
Quote:
![]() 10% is "significant" in my book. If you know that you always have this blend (some areas only get it seasonally), I would change the stoich point accordingly. Keep in mind that ethanol is ~112 octane, so as you mix it in greater %'s, the knock threshold goes up as well. I recommend you take advantage of this with a bit more ignition lead at WOT once you've got the proper AFR.
__________________
#7 | ||
Quote:
__________________
#8 | ||
Quote:
EDIT: Finally found the answer with a search. I guess I'll have to look to an E40 PCM swap if I want it to work. Last edited by Rhino : 04-29-2008 at 02:11 PM. |
#9 | |
I did some experimenting with the stioch afr in my 07 silverado. I have e-10 where i live so I changed the stoich afr to 14.1 because i do not have a fuel comp sensor. I figured my fuel trims would go positive to shoot for the richer mixture but I was wrong. The pc was actually pulling fuel. mind you this is in closed loop. I then changed the stoich to 15 to try lean cruise. The pcm started adding fuel thus positive trims. Just a little food for thought.
#10 | |
Супер Модератор
There are flex fuel truck cals that you could run in a car application. You'll lose VATS though. Then you can wire in the flex fuel sensor from the trucks. 04 Vette/GTO/Truck used the same PCM and the truck had flex fuel capability.
__________________
#11 | ||
Quote:
Do you happen to know if the '04 GTO used the same PCM as the '05+ years? A better way to word the question would be; Can a more modern PCM could be used with a 24 tooth reluctor and cable throttle body? If I can find one, it would save some time and money by not having to do a significant amount of parts swap on my engine as well. (reluctor wheel, front cover, cam sensors, etc...) EDIT: It looks like the GTO retained the 24 tooth reluctor through it's run. It was the Crate and Vette motors that swapped to the 58x reluctor. The '04 GTO utilized a cable actuated throttle. As long as the same PCM was used on the '04 as the '05+ GTO's I think it would work. Unfortunately the wiring harness is completely different between my '02 LS1 PCM and the E40. Looks like I'm needing to do a little searching. Last edited by Rhino : 04-30-2008 at 10:07 AM. |
#12 | |
Супер Модератор
None of the LS2 or later engines (05+ GTO/SSR/Trailblazer SS) run cable throttle so I would go with the 04 PCM.
__________________
#13 | |
Junior Tuner
So am I correct to assume that no vehicle (trying to determine if my '07 NBS Sierra has this sensor) that is not E-85 compatable has this Fuel Composition Sensor and that the Stoich AFR table that goes from 0-100% alcohol content is only reading the 0% field to come up with the AFR?
__________________
2007 GMC Sierra Z71 SLT Crew Cab 4x4 6.0L 4l70e Modifications: True Flow Cold air Intake, HPTuned (Removed HUGE PE Delay, Added 30 to speed limiter, modified AFM/DOD for mileage increase)
#14 | |
Junior Tuner
Anybody?
__________________
#15 | |
Супер Модератор
The NBS trucks use the "virtual" sensor" as in no actual sensor.
__________________
#16 | |
Here's some questions:
1. How do you KNOW how much exact ethanol is in your fuel? Don't the pumps say "MAY contain UP TO 10%"? 2. I'm assuming after you change the stoich, you'll have to go redo all of your VE/MAF tables all over agian.
__________________
2004 IBM GTO M6 - FTI Cam. Kook's Headers. Fast92. |
#17 | |
Супер Модератор
^^ A VERY good point! Up to does not mean =.
__________________
#18 | ||
Quote:
The sticker on the pump and a test kit (which I'm sure aren't cheap, if even available) are probably the only ways to tell. ![]()
__________________
#19 | |
Great thread, we now get E10 year round so this of interest to me.
What kind of adjustments would be needed for WOT fueling? Would the same parameter apply as described above, that is, E10 stoic is 14.03 vs 14.69 for gas, or 95.5%...so if I want to run 12.6 WOT AFR, should I run 12.04 AFR at WOT? I should add that I've got a wideband installed and access to a dyno and try to tune my car for highest horsepower yet remain safe as I drag race it quite a lot. So since I'm stuck with the lower BTU content of E10 I'm interested in knowing if I can get more power out of it. I know at my last 2 dynos (with E10, though I didn't think about that at the time) I'm getting best power at about 12.6 (never tried richer and leaner has no more power) and 24 degrees of timing (more timing doesn't add power, and it doesn't knock at 24). Also - for those that adjusted stoic to 14.03, did you notice any change to MPG or the way the car runs and drives?
__________________
2005 LeMans Blue Vert Z51 MZ6 Mods-Horsepower Sales 954-984-8040 Wide Body/paint-Pride Auto Body 954-545-0811 4:10's, Vararam, FAST 92, A/R Headers w/cats, G5x3, Cometic .040 gaskets STOCK CLUTCH 450rwhp/408rwtq Best pre-cam:1/4-1.730, 11.810@118.76 1/8-1.633, 7.618@92.21 DA 1000 Best w-cam, pre-FAST 1/4-1.666, 11.540@121.39 1/8-1.666, 7.433@94.31 DA 1681 Best w-cam & FAST 1/4-1.530, 11.223@125.19 DA 269 1/8-1.551, 7.213@95.10 DA 789 Top speed 183 (so far )
#20 | |
I'd like to know that, too. You have me wondering if that's why my truck has always been so knock prone. Even though it is 93 octane, maybe I still need more fuel in boost. It's been a lot of years since we haven't had E10 here.
__________________
2000 GMC 2500 2-bar SD 408, Whipple, FMIC, AFRs, LTs, Vic Jr. |
| Thread Tools | |
