HP Tuners Bulletin Board
Go Back   HP Tuners Bulletin Board > Tuning > GM V8 Engine Tuning - Gas Vehicles (Gen 4)
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools
Old 02-05-2008, 01:17 AM   #1
fasttrackperformace
05 c6 e40....best map sensor for 2.5 sd
I have read that the GM pn 12580698 is a 2.5 bar sensor. I was told by another person that it is a 5 pin sensor with an integrated IAT. I called my local GM place and they told me its was 3 pin. To sum it up.....I am looking for the best 2.5 bar sensor to use with the 2.5 bar custom os for the e40. I dont want to buy the wrong sensor and pigtial. TIA
fasttrackperformace is offline
Old 02-05-2008, 01:31 AM   #2
EC_Tune
Супер Модератор
EC_Tune's Avatar
Send a message via Skype™ to EC_Tune
There is no 2.5 Bar sensor that is MAP only. The 0698 version is 2 bar (15 PSI boost) So unless you are going above ~15 PSI you are good. If you are headed for 2.5 bar (Max ~21 PSI Boost) you will have to get one of the old "brick" style 3 bar MAP sensors and run a vacuum line.
__________________
Dynamic Tuning Solutions & Strictly Performance are now one!
We are induction, exhaust, engine, transmission, and suspension specialists in the Los Angeles area.
We do all Gen III segment swaps - email your file to EC_Tune
818-342-5693 for purchases and/or appointments
sp_motorsports@hotmail.com
7444 Reseda Blvd. Suite K
Reseda, CA 91335
Always Support Our Troops!
EC_Tune is offline
Old 02-05-2008, 01:32 AM   #3
fasttrackperformace
Thats what I wanted to do but there is a 256kpa limit in the computer. I am looking to run over 15 psi.
http://www.hptuners.com/forum/showth...1186#post81186
People are mentioning this number as 2.5 bar map sensor. I wouldn't mind if it was 2.5 map and Iat. If the Iat was correct I could just use it....or leave it unwired if not. Right?
Old 02-05-2008, 05:58 AM   #4
Bluecat
Everyone says you can use a 3 bar map with the 2.5 os, but how? I understand that os still stops at 255kpa reguardless, but you can't even configure it for a 3 bar sensor. The map linear has has a max value of 256. Unless you can plug in a value around 300, I don't see how you can make it read correct.
What's the purpose of the Linear B?
Bluecat is offline
Old 02-10-2008, 03:34 PM   #5
Chris@HPTuners
HP Tuners Owner
Chris@HPTuners's Avatar
You need to be careful with the Cobalt becuase they have 3 MAP sensors if i remember correctly.
1. combo MAP + IAT goes in the manifold, 2.5 bar
2. inlet air pressure (in the intake path) 1 bar i think
3. baro sensor (2 bar i think)
You should be able to wire up the 2.5bar MAP + IAT sensor and just not use the IAT part.
The numbers for this sensor are linear 270.59 (the max you can enter is 256) and offset -3.30, which i think the min you can enter is 0. It will be close but not exact.
In the later E38 ECM the limits are different and you can use a 3bar sensor no problems. I was getting confused between the two in a previous post as i was working on the E38 code at the time. Sorry.
Chris...
__________________
I count sheep in hex...
Chris@HPTuners is offline
Old 04-20-2008, 08:31 PM   #6
INTMD8
Stumbled across this post so I figured I would add some info.
A 3bar map sensor will not work properly. Since you can't enter a value higher than 256 it will always read incorrectly. (I had a 3 bar installed and read map values while applying regulated pressure to the sensor and a boost gauge). I'm sure you could install and use this sensor but your KPA reading will never actually be right.
2 bar obviously only reads 2 bar, so a real 2.5bar sensor is needed.
I found this sensor online-
20-250kpa and inexpensive.
http://www.freescale.com/files/senso...t/MPX4250A.pdf
http://www.mouser.com/search/refine.aspx?Ntt=MPX4250AP
Installed it in an 05 C6 with APS twins, re-tested with regulated air/gauge and it reads up to 256kpa while matching boost gauge values perfectly.
INTMD8 is offline
Old 04-20-2008, 08:40 PM   #7
Bill@HPTuners
HP Tuners Support
(foff667)
Send a message via AIM to Bill@HPTuners
Thanks for the info, I think I'll sticky this thread
__________________
Bill@HPTuners is offline
Old 04-21-2008, 07:58 PM   #8
INTMD8
No problem.
INTMD8 is offline
Old 11-28-2008, 09:31 PM   #9
Badassbird
Send a message via ICQ to Badassbird
So I am just checking before I go ahead and order this for a customer. Is the above freescale sensor the way to go with the custom 2.5bar os?
__________________
&&Scott racing and Performance&&www.ts-performance.com&&937-743-2505
Badassbird is offline
Old 11-28-2008, 10:31 PM   #10
VYSSLS1
yep that sensor is a true 2.5bar, it is used in a lot of after market ECU's here in aus and works a treat
VYSSLS1 is offline
Old 05-14-2009, 11:18 AM   #11
TYRFRYR
TYRFRYR's Avatar
Quote:
Is this a brick style sensor or does in fit into the MAP port on the LS3 intake maniflod ?
__________________
2009 - PSB - G8 - A6
TYRFRYR Magazine Article in April 2010 issue of HPP
TYRFRYR is offline
Old 05-14-2009, 01:05 PM   #12
5_Liter_Eater
5_Liter_Eater's Avatar
fits in the manifold.
__________________
Bill Winters
'05 Black on black M6 Z51 - 617 RWHP / 567 RWTQ - ECS Paxton 1500 kit and blower cam, 1 3/4" long tube headers, Z06 H-Pipe, Corsa Sport exhaust, stock injectors enlarged to 60#/hr by FIC; 2 bar speed density tune by me using HP Tuners and AEM UEGO
"When life hands you lemons you upgrade to a C6." - Me
5_Liter_Eater is offline
Old 05-14-2009, 04:45 PM   #13
TYRFRYR
TYRFRYR's Avatar
Thanks Bill,
P.S. Is that a Lap day at TMS??
__________________
TYRFRYR is offline
Old 05-15-2009, 06:08 AM   #14
5_Liter_Eater
TWS in College Station. Lots of fun!
__________________
Bill Winters
Old 06-22-2009, 07:00 AM   #15
rcsfastgto
I have this map sensor can someone tell me how it hooks up to my 05 gto wiring and what I have to change in the E40 and or tune? TIA
rcsfastgto is offline
Old 01-04-2010, 05:11 PM   #16
Ironmancan
Ironmancan's Avatar
Bump...
__________________
06 Twin Turbo GTO
Ironmancan is offline
Old 01-06-2010, 08:38 AM   #17
5_Liter_Eater
It just plugs in...
__________________
Bill Winters
Old 01-06-2010, 01:45 PM   #18
c6dude
Junior Tuner
c6dude's Avatar
Send a message via ICQ to c6dude
Here is one I made that uses the Mouser electronics unit that is plug and play.
http://www.dpecorvettes.com/gpage4.html
__________________
Check out my videos http://www.youtube.com/profile_videos?user=C6Dude402
My Website www.dpecorvettes.com
c6dude is offline
Old 04-17-2010, 11:05 PM   #19
Snyper
Im using this sensor in my car right now and it seems to work pretty good. Im using a linear of 256kpa(is this correct?) and my factory 1bar setup read 103kpa key on engine off..so I set the offset to 9 to get to the same 103kpa..
__________________
2004 350z/LS2: 317s, 228/228@114, PT88,83#injectors/full return system. 10.84@138
Snyper is offline
Old 04-18-2010, 05:42 PM   #20
c6dude
Junior Tuner
c6dude's Avatar
Quote:
Snyper
The Sensor's range is 20-250kp
0.2V = 20 kPa - 2.9 PSI
4.9V = 250 kPa -36.25 PSI
Accuracy +- 1.5% of the full scale value (+- 0.5 PSI)
This sensor is linear which makes tuning easier.
Here is a chart that should help you out.
Perry
__________________
c6dude is offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.12
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
