Results 1 to 9 of 9
Thread: What would cause LTFT bank 2 to be -100%?
    Tuner Joe_G's Avatar
    Oct 2006
    Ft. Lauderdale, FL
    115
    Scanned a buddy's 98 C5 last night and his bank 2 LTFT was -100% across the board and not changing, bank 1 was normal, -3% or so, something reasonable. I cleared the LTFT's via VCM controls but it instantly went back to -100%.
    STFT's both banks were normal looking and changing like normal. O2 readings both banks were normal looking, switching back and forth like normal. Only the bank 2 LTFT of -100% looks odd. Car is running great.
    I can post a log tomorrow if needed, it's not on this computer.
    What's causing this?
    2005 Vert Z51 MZ6
    Horsepower Sales 954-984-8040
    4:10's, FAST 92, A/R Headers w/cats, G5x3, .040 gaskets AFR 205 heads ORIG CLUTCH
    472rwhp/414rwtq
    Best pre-cam:1/4-1.730, [email protected]
    Best w-cam, pre-FAST 1/4-1.666, [email protected]
    Best w-cam & FAST 1/4-1.519, [email protected] DA-793
    Best w-cam & AFR heads 1/4-1.445, [email protected] DA-581 1/8-1.445, [email protected] DA-581
    Top speed 185 (so far...) 0-60 mph 2.59 sec (track)
    http://www.youtube.com/watch?v=DUX3UNFl124
    Tuner RedWS6 00's Avatar
    Mar 2006
    Hampshire, England, UK
    66
    I've never seen fuel trims go more than+/-25%.
    Check that you are logging the same fuel trims for both sides, there are about 8 PID's for fuel trims. Some SAE. Its easy to log the wrong one.
    You say you are logging the O2's switching, are you logging the front O2's, these are used to work out your fuel trims.
    If you can post a log we should be able to nail this problem. As the car is running okay, there cant be anything major wrong.
    When posting the log, can you post the config file too.
    2000 Red TA WS6 M6 in England, UK
    Patriot Stg.II Heads & 226/226-112 0.585/0.585 Cam. Corsa Cat back, F.A.S.T LSX Intake / F.A.S.T Fuel rails, Dynatech LT's/Y, Wisper Lid, ported MAF, 52lb/hr. 160 stat. !AIR, !EGR. Walbro 255, SPEC Stage II.
    HPTuners 1BAR SD Tune. Wide Band AFR.
    389RWHP/380RWTQ ([477HP/460TQ]Flywheel) Dyno Dynamics
    Photos at:- http://www.solent-renegades.co.uk/ca...00trans-am.asp
    Quote Originally Posted by Joe_G
    I would hazard a guess that because this is a 98 you have a 24 byte limit and if you have exceeded that then one of your PIDs will not read accurately, reduce your PIDs to under 24 bytes and try again and I suspect that will cure your issue. I am sure I have read this previously.
    Cheers
    Oct 2006
    Ft. Lauderdale, FL
    115
    Quote Originally Posted by SSUte01
    Cheers
    Well this very could be - I've got a LS2 and I just used my config file when scanning his car and I've got the pid's set up for my car and I know added a few from the stock config file.
    I'll post up the scan later today.
    Thanks boys!
    2005 Vert Z51 MZ6
    472rwhp/414rwtq
    Oct 2006
    Ft. Lauderdale, FL
    115
    Here's the scans. Appreciate any and all comments.
    2005 Vert Z51 MZ6
    472rwhp/414rwtq
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,213
    Like SSUte01 said, the 1998 only supports 24 bytes, your using 26. Remove the O2 mv pids to get down to 24 bytes max.
    Russ Kemp
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    I saw the same thing on a friends 98 as well. I seem to remember it was both banks though, but I knew the trim(s) stated 100%. Car ran great as well, so I knew it was a false reading. I reloaded the .config and started the scan over and all was well again, was wierd.......
    The 98 is a strange beast
    [email protected]
    Oct 2006
    Ft. Lauderdale, FL
    115
    Quote Originally Posted by Russ K
    Russ Kemp
    Perfect. Thanks for the help guys!!
    2005 Vert Z51 MZ6
    472rwhp/414rwtq
    Nov 2010
    45
    This happened on my 05 CTS-V a few times. Disconnect, re-connect and it went away. Happened twice this last week.
