We've incorporated a number of powerful new features that brings the HP Tuners solution well ahead of any stock operating system solution. Here's a quick rundown on the features, some of which will be familiar to those that have used our enhancements before.
This E38 enhancement contains the following features:
- 2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors)
- Rescaled MAF High Freq table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec
- New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution)
- Charge Temperature based VE multiplier table, configurable axis
- TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes
- MAP referenced Boost Enrich table
- Boost Enrich MAP threshold and hysteresis value
- Both MAF and Speed Density mode supported
- Boost based fuel cut, selectable MAP threshold cuts fuel to all cylinders when exceeded
- Rescaled fan temperature axis 163-250F (73-121C), stock is 192-250F (89-121C)
The MAF High Freq table has been rescaled to 5800-15400Hz at 300 Hz resolution and the maximum airflow limit for this table has also been adjusted to allow up to 1024 g/sec (instead of the stock 512 g/sec). This is excellent news for boosted applications that want to retain the MAF but reach higher than the stock 12200Hz and 512 g/sec limits.
