Page 13 of 14 FirstFirst ... 391011121314 LastLast
Results 241 to 260 of 271
Thread: 60lb Inj. Problem
  1. #241
    Advanced Tuner SJSchafer's Avatar
    Jul 2007
    San Jose, CA
    224
    Quote Originally Posted by 03Sierraslt
    I would love to get real offset Numbers... However that seems to be the problem.
    I have them. Care to donate to the "Steve lost his ass in Vegas" fund?
    Quote Originally Posted by BlackSS/SC
    Hey man, finally got to play around with the car last night. It is so much smoother with these PW settings.
    '07 Cobalt SS/SC
    Mods:
    I has a couple.
    Questions about 60s? <-- click!
    How to tune for return fuel system <--click
  2. #242
    Jun 2006
    Western Pa.
    331
    Depends what donations are..
    04 Sierra Denali,370,S485B, Built 4L80E, 3barOLSD, E85
  3. #243
    Nov 2005
    Houston, TX
    3,968
    Subscribing
  4. #244
    Apr 2006
    Grande Prairie, Alberta
    110
    Hell yeah, car is so much better now. Those PWs were pretty damn close to perfect. Car is smooth and doesn't buck or surge like it did before at low RPM stuff
  5. #245
    Jul 2007
    San Jose, CA
    224
    Can I quote you on that?
    '07 Cobalt SS/SC
    Mods:
    I has a couple.
  6. #246
    Dec 2004
    Laurel, MD
    1,020
    I'll get on the 'woot-wagon' for Steve as I just tried it on a 427 last weekend and in OL-MAF and no WB I got them to behave very well, car idles at about 2.1ms warm and 2.4-2.5ms cold.
  7. #247
    Jul 2007
    San Jose, CA
    224
    Quote Originally Posted by redhardsupra
    Wow! Thanks Marcin. I'll take that compliment!
    '07 Cobalt SS/SC
    Mods:
    I has a couple.
  8. #248
    Apr 2006
    110
    Quote Originally Posted by SJSchafer
    Sure man, you helped me out
  9. #249
    Apr 2006
    37
    Can anyone share the values, I'm still lost???
    1998 CAMARO LS block w/Lunati 383, 8.375:1 TR230/236 @50 w.575 lift, Procharger F-1, 60# Motron injs, LSX intake w/ 90mm NW TB,GTP heads, Twin Aeromotive A1000 fuel pumps, Kooks LT w/cats, GMMG exhaust, LGM/Howe Aluminum rad w/oil cooler, Meziere pump. 6 point cage, QA1 Double Adjustable aluminum threaded body shocks 500f/200r springs, Wilwood 6 piston front 4 piston rear calipers, SS braided brake lines. T-56 Transmission: Spec clutch Moser 12 Bolt 4.10:1 w/H.D. internals.
  10. #250
    Jul 2007
    San Jose, CA
    224
    Quote Originally Posted by APD*98SS
    New how to:
    http://www.hptuners.com/forum/showthread.php?t=17962
    '07 Cobalt SS/SC
    Mods:
    I has a couple.
  11. #251
    Tuner Dozer's Avatar
    Jul 2007
    Sparks NV
    106
  12. #252
    Jul 2007
    San Jose, CA
    224
    Quote Originally Posted by Dozer
    lol. Thanks. Not sure why this guy is trying to fight with me though. lol
    '07 Cobalt SS/SC
    Mods:
    I has a couple.
  13. #253
    The 79# Racetronix do the same thing but worse.
    Nobody has any info on the set up anywhere. Tried using the 60# specs and it still miss fires at idle/off idle and has no power. I was better off with 102% DC on the last injectors.
    I feel as though I own the only set of 79# injectors in the North American continent; or at least know ones talking
    2005 Chevy Crew Cab s/b
    Vortech blown 5.3/air to water IC/finish line 4l80e/ stall / Running on E98 ethanol
    2008 Silverado- Vortech VL Twin screw supercharger. SEMA 2008 Vortec Engineering Booth
  14. #254
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    Good work guys
    I may be able to give some perspective.
    I'm running Siemens Deka 62s on my NA 358 96 Impala with a retun fuel system.
    This may give some validation to the numbers as it is a basic hyd. roller build with a simpler PCM OS.
    No IFR on this ride just a simple injector constant.
    No flow rate modifier... the injector constant goes up to 2500lbs per hour.
    SPA table logic is different min inj pulse and Low Pulse width offset...
    The motor is ultra efficent and under sized for the 62s.
    Two stage dry kit and 700RPM will take care of that in a hurry.
    The point is I'm seeing .7-1.7ms at cruise on the freeway.
    I can actually see .7ms under load at 14.7 AFR.
    I can do steady state driving on the Low pulse width offset table.
    *that is if my scanner is not lieing to me.
    If I can get accurate injector offst vs system DC I can actually test the low Pulse Width Offest table under load VS the WB.
    I can check it in MAF or SD modes as I had a SD and MAF tune that worked great with 42s.
    I am running a blanket 977 usec injector offset vs battery at all normal system voltage ranges for now.
    Anyone want to take a stab at what my Inj Offset Table shoulb be on a return fuel system with a intake manifold vacuum referenced pressure reg.
    For now I will try
    15.99 0.33886
    15 0.33886
    14 0.41210
    13 0.48925
    12 0.59082
    11 0.74121
    10 0.93359
    8 1.44628
    6 2.54101
    0 2.54101
    0 2.54101
    0 2.54101
    I have ended up with a Very steep low pulse witdh injector offest as well.
    BPW - Adder
    488 - 747
    549 - 747
    610 - 747
    671 - 564
    732 - 534
    793 - 457
    854 - 396
    915 - 366
    976 - 351
    1037 - 351
    1098 - 213
    1159 - 198
    1220 - 61
    1281 and up zero
    I'm not quite done with this table seems a that it may not be steep enough at the bottom as it goes 16.5 - 17:1 just a hair before DFCO under .8ms.
    And I have a rich spot at light cuise that is very narrow in kpa, my guess is .976-1.100ms.
    Hope this helps
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
  15. #255
    Mar 2006
    sunny So Cal
    292
    I have done bigger badder LT1's and 433 and up cube LS1s with SD62.
    But they are thirsty and dont quite sip fuel like my little 358 LT1.
    NotoriouSS TAD
  16. #256
    Mar 2006
    sunny So Cal
    292
    How come the table posted here is different from the injectors PDF?
    SD 62lb pdf
    Quote Originally Posted by RWTD View Post
    Injector Compensation for Battery Voltage:
    [code]
    VOLT PW ms
    15.99 0.33886
    15 0.33886
    14 0.41210
    13 0.48925
    12 0.59082
    11 0.74121
    10 0.93359
    8 1.44628
    6 2.54101
    0 2.54101
    0 2.54101
    0 2.54101
    NotoriouSS TAD
  17. #257
    Dec 2005
    Sydney Australia
    510
    Quote Originally Posted by Blown View Post
    i used them and never had a problem, idled fine and made plenty of HP
  18. #258
    Mar 2006
    sunny So Cal
    292
    RCI 74lbs @ 3bar in a customers 05' T56 LSX APS+ GTO
    they were pretty easy to tune vs the SD 62s
    NotoriouSS TAD
  19. #259
    Quote Originally Posted by VYSSLS1 View Post
    I'm really at my wits end here, could you help me out with my set up?
  20. #260
    This is what i'm using ( I have tried more than 100 combinations since this).
    It's always the same result...
    Settles into a 13.5AFR idle
    Misfire in cylinders #2 and #7
    Hesitation off idle with no power
    Goes real rich if you give it any pedal
