I've seen alot of people when they go to Speed Density mode from Maf mode see their Dynamic cylinder air reading in their histograms or graphs read 1/2 of what it reads in the table display.
This is caused by the maf reading still being in the table display and reading a steady number.
Since dynamic cylinder air can be calculated from maf as well as by other ways when you leave the maf sitting at a steady reading the program still tries to calculate dynamic cylinder air off of this faulty reading then averages it together with the other calculation finally giving you 1/2 of what the real reading should be.
The simple fix is to NOT log MAF(SAE) in your table display when your not using it
-Bill
