i have a FLT Stage 4 4L60e trans with a Yank SS400 converter. everything has worked fine on the car since i have had the setup and Speed Inc tuned the trans....roughly 3 months of driving on it.
recently i have been getting the P0757 code. I talked with Chuck at FLT and he said that the converter sometimes throws this code and to delete it out of the system.....this has been done.
my problem is that for the last couple of weeks while i have been throwing the code my converter is not locking up. there are no SES lights on currently. and the codes are deleted.
I have read on some other sites that the misfire tables need to be maxed out, but i have tried this and the converter will not lockup. even when i try to manually lock it up through HP Tuners it will not.
what could be causing this problem? is it possible that i have a bad converter?
