I thought it would be nice to start a thread of Custom PID's..created by Users
If you are using something and would like to share..please feel free to post...
if I get enough of them I'll make a sticky....
I'll start with...
I'll start with...
-Scott -
MPG - Requires: MPH - Injector Flow Rate - InjectorPulse Width - RPM - IAT - ECT and 8 Cylinders - works on LS1's for sure
[SENS.20]/(([PID.6210]*0.132276)*[SENS.112]*[SENS.70]*8/(6175*(((([SENS.11]+[sens.10])/2)+273.15)/299.8167)))
Boost Amount - Requires: MAP
[SENS.30.IMP]-14.503773773020923
LTFT+STFT - Requires: LTFT - STFT
[SENS.114]+[SENS.116]
EQ Ratio to Commanded AFR - Requires: EQ Ratio
14.7/[PID.6010]
RAF In Gear - Requires: Idle Adapt(STIT) - LTIT Gear/AC Off
[PID.2240]+[PID.2229]
RAF Park/Neutral - Requires: Idle Adapt(STIT) - LTIT PN/AC off
[PID.2240]+[PID.2231]
-Scott -
Gee I'm a neebie, LOL!
So for 6 cylinders, is this correct?
[SENS.20]/(([PID.6210]*0.132276)*[SENS.112]*[SENS.70]*6/(6175*(((([SENS.11]+[sens.10])/2)+273.15)/299.8167)))
2007 Pontiac G6 GTP ~ 3.6 VVT (LY7 10.2:1) w/ 6 speed auto/manual tap)
14.358 N/A @ 96.57 mph
2001 Regal LS ~ L32 GenV M90; PLX SM-AFR WB; 3.4 Blower Pulley; 18* WOT; XP CAM; TOGs; N* TB; Dynotech Stage 2 Trans
13.288 @ 104.23 mph
Car Domain: http://www.cardomain.com/ride/2291346/1
I dont know if it works on 6cyl or not...but that is part that would have to change for 6 cylinder..some of the sensors would have to be double checked...I dont know what the 6cyl guys are doing..somebody around here made it work for them....Originally Posted by dlclarkiiRegal
-Scott -
Is there a link on how to setup custom PIDs? I have the table display open, I right click on a blank cell, then double click on configure user defined and then I get a window but now what, I can't save it, do I need the MVP plugged in? I'm confused. Thanks
13.288 @ 104.23 mph
theres no save button...Originally Posted by dlclarkiiRegal
just close it out when you are done..
I also find that I usually have to close the scanner and re open it..I dont know why..I'll address it in our moderator section
-Scott -
Originally Posted by soundengineer
I got it to work, same way as you described it, I have to close the scanner and reopen it for it to be available. Thank you.
13.288 @ 104.23 mph
its actually a known bug to our mods and other staff....posted in our bug report for the latest build...its being worked onOriginally Posted by dlclarkiiRegal
ok..with that aside..anybody else have any useful custom PID's that you are using??
even if they might be vehicle specific??
-Scott -
Scott,
I'm planning on trying to do 2 for the LS2..
IFR is not a supported PID for the LS2. I am thinking there is a way to create one, I just need to figure out the math Utilizing:
32lb injector
Injector duty cycle
Ambient air temp (Engine>Airflow>Ambient Air Temp)
One would think a IFR could be created.
Since IFR is not a valid PID your MPG PID does not work. I was going to try and figure out how to get that going once my IFR PID was up and running.
My biggest thing right now is I am not sure how to figure LB's minute based on injector pulse width. Any help in this area would be great.
injector sizing is
=IFR*SQRT((Rail pressure+Vackpa*KPA)/RatedtPSI)
Injector Pulse Width is
IPW=120*Dynamic Airflow/(Cyl*RPM*commanded AFR*IFR)
do some math and you can turn that last formula into IFR
so IFR=120*Dynamic Airflow/IPW*(cyl*rpm*commanded afr)
maybe???
120*[pid.2320]/[sens.112]*(8*[sens.70]*[sens.121])
this would be ls1...just need to do some unit converion yet possibly
possibly a few different pid #'s on other vehicles
this is all rough just from formulas I found using google
I have no way to test this right now..LOL
-Scott -
Scott, please do me a favor and do not abbreviate I'm just learning the scanner side of things Now I got to figure out what most of that is.. Or if you do, say what it is first.. Thanks a ton
So I am assuming IPW is injector under sensor not [PID.6200] or [PID.6201]
The function string you posted seems to be what I come up with as well again assuming you are refering to sensor 112 for IPW
PID.6210 is IFR for LS1's it seems. This does not exist in the LS2 world (at least on the 07 TBSS I have). So with:
120*[pid.2320]/[sens.112]*(8*[sens.70]*[sens.121]) as IFR
[SENS.20]/(([PID.9005]*0.132276)*[SENS.112]*[SENS.70]*8/(6175*(((([SENS.11]+[sens.10])/2)+273.15)/299.8167))) would be the new MPG PID (9005 is in red because it may show up as 9004 through 9010, you will have to find it).. This is not verified due to the Fiance being out
IFR = Injector Flow RateOriginally Posted by Super73
IPW = Injector Pulse Width
Cyl = Cylinder
AFR = Air Fuel Ratio
RPM = Revolutions Pre Minute
SQRT = Square Route
IAT = Intake Air Temperature
ECT = Engine Coolant Temperature
MAP = Manifold Absolute Pressure
kPa = KiloPascals
PSI = Pounds per square inch
vac = vacuum
LTFT = Long Term Fuel Trims
STFT = Short Term Fuel Trims
LTIT = Long Term Idle Trims
STIT = Short Term Idle Trims
IMP = Imperial
MET = Metric
MPG = Miles Per Gallon
RAF = Running Air Flow
that should be all my abbreviations..LOL
-Scott -
Thanks Scott.. I'll let you know how the custom PIDS for IFR and MPG work once I get the TBSS back (Wed time frame)..
I might be able to test it sooner with a rental car on my trip to canada I am takingOriginally Posted by Super73
-Scott -
so I mised a pair of () in there for sure
120*[pid.2320]/([sens.112]*(8*[sens.70]*[sens.121]))
and I still need to figure out unit conversion
pid.2320 is lbs/minute
sens.112 is in milliseconds..so we need /1000 times 6 or times 0.006 for per minute
sens.70 is in revolutions per minute
sens.121 is afr
IFR is lbs/HR. so times 10 making 120 = 1200
I know I'm missing a lot on this one somewhere..LOL
convert all from per minute to per hour
(120*([pid.2320]*60))/(([sens.112]*0.036)*(8*([sens.70]*60)*[sens.121]))
??? maybe??
need some more help from somebody with more knowledge....LOL
-Scott -
Can't get IFR nor MPG working
http://73-ls1.com/New3.cfg
Anyone have some input?
I playe with it the other day...the rental car I got is a hyaundi...so I cant even begin to try..LOL
I know its just a formula issue...maybe in units conversion...
I just havent had any time to try to figure it all out...
we've been working way too many hours and crunching a lot of #'s here and I just dont want to do any math at the end of tehday..so I havent even looked at it here while I'm in canada....
-Scott -
I've been workin in your formulae for my V6. Been able to get most things to work (need to check the actual numbers). Not havin any luck with the mpg though. Seems I have an unsupported parameter, but when I scan each individual PID.* or USER.* or SENS.* they are ok..... when I have some time, I'll post what I have to supplement Soundengineer's work... I made a lot of assumptions though
