Alot of people are confused by the terms and the rating system so I'll try to explain a bit. A few people have come to me saying "I've got some 30lb injectors I wanna install how do I figure out what my IFR table should be" The first question I always ask is "What psi are the injectors rated at?" and undoubtedly the answer is always "I don't know" lol. So first things first Understand there is a ratings system when it comes to injectors where they are rated in bars or psi...1 bar=~14.5psi so when a company says "We've got 40lb injectors rated at 3 bar" that also means they are flowing 40lb/[email protected].
Now here's where it gets tricky & most people don't know whats going on...LS1's generally have their fuel pressure at ~58psi not 43.5 MEANING those 40lbers@58psi are going to flow closer to 45lb injectors and can mean a HUGE difference in fueling characteristics. Most places that sell injectors will show you their ratings similar to this http://www.racetronix.com/17113739.html
You all know about the excel IFR calculator thats already in the sticky so I wont go over that, but it'll basically do MOST of the work for you.
Bottom line to this new sticky is to verify YOUR fuel pressure as well as the fuel pressure the injectors are rated at.
Im leaving this thread open for discussion or corrections of any inaccuracies in the info I've given.
