I don't have the pro version ( I think?) but was using an old Beta one, so just uploaded all the new suite and it seems to work fine. I STILL had a high MAP reading so deleted the MAP PID and reloaded it, and woohoo, it showed realistic readings. The tune is a ways off yet still, I think I need to get the injector timing to match the cam, start injectors right when the ex valve just closes. I don't have a wideband on it but will have to get one. The car won't go much over 4800 rpm before jumping into low power mode. I attached the latest tune and scan, if that is of use.
Nev GTO2.hptNev scan cam4.hpl
