Results 1 to 20 of 20
Thread: E38 ECM speed density won't start until MAF fails.
    08 Silverado running a speed density tune. After a new tune is flashed it won't start at times. Once the MAF fails it will start fine until you flash it again. MAF fail set to 0hz, P0101,p0102,P0103 all set to 0 first error. MAF table is zero out.
    It getting really frustrating trying to get it started. What's going on that I'm missing?
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Put 6 g/s (or about what the RAF would be set to at idle) in the MAF 0 HZ cell.
    should help you ride through the fail setup.
    Post your tune please.
    Ed M
    [email protected]
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Whatever you do make sure you don't kill it till 30 seconds after the fail process!
    Don't worry OP my G8 is being very fussy about it too.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Cycle the key if you aren't already.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Tried cycling the key and repeated reflashing. It's pissing me off.
    28,268
    Start by posting your current tune.
    Here it is.
    Aug 2010
    Roswell, N.M.
    1,956
    Does your truck have an issue with the TPS going down at idle when the MAF fails?
    618/618 motor
    906/862 spray
    Potential Tuner Steve@HPE's Avatar
    Sep 2012
    Florida
    7
    Quote Originally Posted by scooter k View Post
    I had similar behavior and resolved it by increasing the values in the VE tables in the idle area and adding airflow in the idle range to the MAF Airflow vs HZ table.
    Also, the VE correction factor table creates a bias of MAF vs VE airflow, you may want to make sure that's completely biased to VE. Although, I suspect that table is ignored once the MAF fails, but it may play a role in the mean time.
    BTW, there are areas of negative timing in your "Cranking Spark" table.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Steve@HPE View Post
    You part of Hennesey?
    618/618 motor
    906/862 spray
    28,268
    considering you have the maf table 0'd out its pretty normal that the pcm wouldn't run UNTIL you set the maf to fail.
    /thread.
    Mar 2008
    St. Louis, MO
    4,859
    I don't understand why people zero the MAF table for SD.
    28,268
    I believe the custom operating system application process automatically 0's out the maf & ve tables(because it extends the maf table and creates a ve table from scratch), we've found that in most cases the ve table must have at least some sort of baseline even if running SD only(not sure why this is but it is what it is I suppose).
    So I need to put something in the MAF table then even though there isn't a MAF at all? Anything else?
    Mar 2008
    St. Louis, MO
    4,859
    The only MAF table that gets zeroed out is the MAF High in applications that have two MAF tables.
    Sep 2012
    Florida
    7
    Quote Originally Posted by IDRIVEAG8GT View Post
    No....Hines Performance Engineering. I have family members that race/build motorcycles you may have heard about, but I do cars.
    Mar 2007
    Florida
    3,773
    Is my 2nd post invisible
    [email protected]
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by mowton View Post
    WE ARE ALL BLIND!
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Sweet, I'm glad you're not. I was about to bash you about Hennesey screwed up DynoJet.
    618/618 motor
    906/862 spray
    Mar 2007
    Florida
    3,773
    WE ARE ALL BLIND!
    [email protected]
