Results 1 to 3 of 3
Thread: Room for improvement - tune and log file
    Oct 2021
    8
    I'm pretty happy with where my tune is at but you dont know what you dont know. If anyone has some spare time to take a look and make some suggestions on what I can improve and why, I would appreciate it. I did some SD tuning but currently running the MAF. Truck is an 09 Escalade esv awd 6.2 l9h, stock vvt cam,stock fuel system, twin hx40 turbos, flipped factory manifolds. Wastegates are a little large so have a bit of a falling boost curve but I'm sticking with this setup for a little while and maybe look into ebc in the future. Power is decent and she gets about 18.5 mpg on the hwy and 11ish around the town.
    Still struggling with kr randomly even with good fuel, hardly any advance and the knock sensitivity is turned down a good bit so advice there is helpful too.
    MAF 19 remove some tq mgt from trans.hpt
    9th tq mgmt.hpl
    Tuning Addict
    6,814
    MAF should be smooth. VE needs work, but I think you know that. Injection timing, ignition timing and cam timing will be your big power adders and I mean BIG power adders. Trans could use some work, but you better research it because have to adjust a lot of tables. Fuel eco should be higher with the setup. Wish you had the 2bar as that would have worked out better for you in general.
    ~Greg Huggins~
    Oct 2021
    8
    Thank you. Spent some time today playing with cam timing and following up with some different ignition timing. I?ll post the new tune with a log tomorrow to see what you think.
    I?m ignorant so forgive me, what do you mean by 2 bar? I have the ZR1 map sensor, maybe you mean something else?
    For transmission I?ve been using the BlueCat program and that?s about it. If you?ve got any pointers or things I should research please let me know.
