Basically the problem I'm having is going rich on decel. It's not terrible, but I'd like to see if you guys can help me sort it out.
I copied some injector values from a tune I downloaded on here, and it helped, but it's not quite right yet. I don't know the proper way to figure out what these values should be (offset, pulse adder, etc...). Actually I really don't even know what they even do.
A little background on the car:
Rail mount vac/boost referenced regulator (58 psi @ atmos, 43 or so at idle)
I had the injectors flowed and they averaged out to about 63 lb/hr @ 3 bar.
2 bar MAP OS, still working on the VE table in open loop.
I'm trying to get the part throttle tune close (still in progress) before I put the turbo kit on. This is my first turbo car, and first tuning experience, so I'm taking things slow.
If there's other things that I need to log, I can take the car out for another cruise, I'm not sure where to go from here.
Thanks guys
Craig
