I spent about 6 hours on the dyno with my friends 02 Z06 yesterday. He has AFR heads that give this car 11:1 compression. He runs 93 octane. KR started removing timing in a couple spots on the dyno and no matter how much timing I removed it wouldn't be consistent. It wouldn't be there one run and then come back slightly the next, and the a lot on the next. I was down all the way to 16 degree's. AF was solid in the 12.6-12.8 range.
So what I decided to do was turn off the knock sensors and start to add timing back in 2 degrees at a time. The car didn't lose any power or torque all the way to 26 degrees. It started not to gain any more power at that point so I backed it off 2 degrees. So it appears that these sensors are pretty crappy. Does anyone change the sensitivity on them or has anyone had a problem with them before?
