Howdy I need some guru knowledge, I have a 99 Z28 m6 with 5.3l stage 2.5 heads, a tsp 233/239 113lsa cam, long tubes basic other bolt ons. I had the car tuned by a local shop(maf tune from the looks of it) after which it ran ok but very rich after about 5000 miles the car started to hesitate under acceleration. I picked up hptuners and a lc-1 and started logging, after correcting some of the pig rich afr the car is still pulling timing when the MAP kpa is above 75. I will attach the log file of a quick wot run, this is after taking timing out of the spark table. Changes to PE and VE tables don't seem to have much effect on the knock retard that I am experiencing, and pulling timing out of the spark tables seems to make the car run worse and worse. Any suggestions where to go from here would be great, thanks.
Attached is the last tune I tried with a lot of spark taken out.
Attachment 6538
Attachment 6539
