You need to spend a little more time hitting different cells. Below is your log with the cell count set to 25. You don't have any data from 2800 rpm and up. You may want to set the cell count before you start to log, that way, all the info that you are looking at while logging will be usable data. It will just take a little longer before you see data show up in each cell.
