Results 1 to 5 of 5
Thread: 2000 lq4 idle goes to 2000 rpm on first start up
    Jul 2023
    ok guys im new to this so bare with me i have a 2000 lq4 with a sloppy stage 2 cam 862 heads with larger intake and exhaust valves 4l60e 2500-3000 ptc lock up stall converter 45lb aus injectors part# 56010-410-8-D i recently had it tuned but im starting to have issues with the idle going up to 2000 rpm and it takes about 2 minutes before it gradually comes down to around a 1000 rpm any help would be greatly appreciatedtest new cold air intake box.hplje imports performance re-tune stalling and idle adjustments 4-24-24.hpt
    5BA8
    3,556
    You need to post this in the GEN3 section. You'll get no traffic here.
    email=[email protected]
    2,959
    Quote Originally Posted by broncobilly4 View Post
    The TPS % is not returning to zero.
    Sticky throttle body, worn shaft, or bad TPS
    Try disconnecting the battery to clear the zero position first.
    Tuner at PCMofnc.com
    Sep 2021
    Kentucky
    530
    Id really recommend going to a 2002 os file. Here is a file i made with some background changes to make this work. I have lots of issues with the 99-00 trucks starting.
    Jul 2023
    ok guys thx for the input i have not had a chance to get out to the garage to work on it because work has kept me busy i will let you know how it works
