Results 1 to 8 of 8
Thread: LS3 Fuel Pressure Magnuson Heartbeat
    Dec 2020
    Sydney Australia
    18
    I have a 2106 Holden Commodore SS LS3 6.2 with a Magnuson Heartbeat 2300, running 90 mm pulley 7 psi, fuel pressure is dropping to 330kpa in the higher rev ranges but it should be 400kpa , is the fpcm fuel flow rate value right or do i need to increase that or do i need a fuel pump booster?
    Please find attached files
    Dec 2020
    Sydney Australia
    18
    I doubt if that pid is wrong, i have previous logs before the supercharger went on and the pressure never went below 390kpa at 6000 rpm
    7,953
    Oh. Well never mind then.
    Jul 2020
    VIC Australia
    1,197
    Yep, continue on your way.
    Jul 2020
    VIC Australia
    1,197
    Quote Originally Posted by greg666 View Post
    Bet you weren't at 107% duty cycle either.
    2,959
    Log fuel pressure sensor voltage to see if we can catch it not matching what is reported.
    Also.. in the FPCM there are some useful pids like pump PWM %, short and long term pump trims. So if you are short on fueling in your FPCM you'll see it show up there.
    Tuner at PCMofnc.com
    Dec 2020
    Sydney Australia
    18
    Ok i will have a look at those pids see if i can see anything there, thanks
