Results 1 to 3 of 3
Thread: E85 Parameter not populating/reading
    Feb 2019
    Post E85 Parameter not populating/reading
    I have a P59 gen 3 6.0L with a turbo/cam/heads I'm looking to enable the flex fuel sensor. I installed the flex fuel sensor (has 12 volt power, is grounded, and has 5v from Pin 56 in the computer). My issue is that in HP tuner scanner, I am not receiving any alcohol % nor will it allow me to add a ethanol parameter. I also have all the parameters enabled in the tune for flex fuel. The % is 0% for alcohol and no way for me to add ethanol. I have used 2 different computers, 3 sensors and 2 different sets of wiring.
    405
    2,360
    Are you using an actual FF operation system?
    May 2014
    USA
    452
    Did you try "repoll for supported parameters" in the scanner?
    What OS? Tune file would be helpful. I can't remember if alcohol showed up in the scanner the whole time or after I enabled it in the tune only for me.
