Results 1 to 2 of 2
Thread: Unstable WOT AFRs NA 426
    Aug 2020
    31
    I've been fighting an issue for a bit now that run good everywhere except while under WOT the AFRs will bounce around almost as if a cylinder is misfiring or something. Car is an NA 426 11:1 on E85. We've gone over spark plugs, coils, injectors, O2s, and everything else but can't figure this one out. Also having issues with knock retard which I assume is directly related
    Here's a log:426WOT_log.hpl
    Tune file: 426_E85_unstableWOTAFR.hpt
    2010 Challenger R/T - 6.1 crank, Manley H-beams, MMX drop ins, Magnuson 2300, Snow meth stage 1, TSP Stg3 Boost Cam, Stainless Power Long tubes, Fore L2 return dual 450s, Hellcat TB, snout port matched to 90mm adapter, ATI 17% OD Lower 2.8 Upper, 14psi
    5BA8
    3,556
    I think you're seeing noise on the WB input. A miss will almost always be reflected in the narrowband sensors.
    email=[email protected]
