Results 1 to 5 of 5
Thread: 2004 Jeep WJ 4.0L JTEC+ Engine & Transmission
    Apr 2024
    Hey everyone I am new to tuning and I am just trying to fix some Fuel mapping and maybe change my transmission to get a bit firmer shifts. I have a mostly stock 2004 Jeep Grand Cherokee Laredo 4.0L 2WD and I am just wanting to get better performance. I installed 4-Hole 25.5 Bosche Injectors I also have shelled my CATs and have a high flow exhuast. I've learned that there is not a lot of info out there for JTEC tuning. Also If anyone has a stock Tune File for 99-04 WJ with the 4.0L it would be very helpful I saved over mine by accident. I attached a copy of the Tune I have worked on so far for the past few days and I have a feeling many of my values are very wrong. Thank you all for any help!
    Mar 2023
    [QUOTE=RTXLoki;777136]Hey everyone I am new to tuning and I am just trying to fix some Fule mapping and maybe change my transmission to get a bit firmer shifts. I have a mostly stock 2004 Jeep Grand Cherokee Laredo 4.0L 2WD and I am just wanting to get better performance. I installed 4 Hole Bosche Injectors that were a little larger than stock and I have no CATS in my exhust system. Where should I start and What should I be looking for. Also If anyone has a stock Tune File for 99-04 WJ with the 4.0L it would be very helpful I saved over mine by accident. I attached a copy of the Tune I have worked on so far for the past few days and I have a feeling many of my values are very wrong. Thank you all for any help![/QUOTE04jeep stockfile.hpt i think i sent ya my 04 jeep rubicon inline 6 stock tune
    Mar 2023
    im new here too an im tuning my 04 jeep rubicon . im getting ready to install a turbo an switch to a 5 speed manual
    Jan 2024
    Vancouver Island BC
    14
    rtxloki i have done a 4.0 tune or two
    there is no injector constant available in hptuners for that ecm, you need to fix your injectors first. so what you want to do is go ahead and do some datalogs for trims. for a starting point what i would do is take LTFT+STFT and kinda get an average of how much trimming is going on and for starters multiply your whole VE table by that. for example if your trims are kinda -10% then take your whole VE table and multiply by .90. then take more logs and fine tune it from there.
    this ecm is really primitive and a bit finicky to tune
    first thing is i found the stock calibration was like 9 degrees short of timing advance across the board. probably because it has no knock sensor. if you have consistent fuel go ahead and stuff a bunch more timing into it, it'll wake it up a bit.
    shift points are definitely where you see the most gains
    i have attached a stock HPT file from my 1999 WJ as requested. it is a canadian model single cat. i have also attached a tune with really aggressive shift tables and timing that i use on my WJ off road. i recommend copying the shift tables but nothing from the fuel/timing as your injectors and local fuel quality may differ
    the other pain is this thing uses TPS voltage for shifting rather than scaled TPS to a percent so if your TPS is not identical to mine in every way it wont shift right with these tables.
    hope this helps
    Apr 2024
    Quote Originally Posted by rfesu View Post
    hope this helps
    I copied your trans tune and your spark tables I left my fuel tables because I have the 4 hole 25.5lb injectors, My stock throttle body is sanded out to be as many MM as it can be so the taper has been removed, and my CATS are shelled so I have high flow exhaust
