Hi!
Really need help, can't solve my problem. In the process of tune the error P012B appeared and it is not removed. The error appears immediately when the ignition is turned on, when the engine is not even running yet, which is very strange. I can not understand what is the cause. Tried another sensor, the problem is not solved. Tried to make a new wiring from ECM to the sensor, the problem still does not solve. Even disabling DTCs in the settings does not help. I will be very grateful for any hints and help.
corvette_zr1_ver0.6.hpt
ERROR_DTC.hpl
