Results 1 to 2 of 2
Thread: 2011 Raptor 6.2 down shift problem
    2011 Raptor 6.2
    P1Sc
    Built trans.
    Let it shift into 4th - stomp WOT, literally 2 second delay. Log attached at 1:00 mark.
    Tune attached.
    Any ideas? Haven't ran into that before.
    Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    156
    Go into your torque management down shift section in transmission and increase the bottom 2 rows by 80 to 100 lbft in all tables it should help fix the delay I see your values are still stock. Let me know if this helps there is more you can also do to make it down shift faster but you don't want to make it shift to fast. The Trans needs time to have enough fill to apply the requested clutches, not having enough pressure to hold the applied clutches can make them slip.
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
