Results 1 to 5 of 5
Thread: 2021 H/C/I 1SS Camaro idle hangs @ 1000 rpms
    Apr 2018
    4
    can any one point me on the right direction on idle torque tables, thanks in advance
    5BA8
    3,514
    Looks like a combination of things. Your VVE looks untouched. Looks like you have too much idle airflow. Not sure if you've done any VT tuning but all your torque pids are in the negatives. It would help if you posted your unmodified tune file.
    email=[email protected]
    Apr 2018
    4
    stock file has been posted, thanks!
    Tuning Addict
    6,873
    Seems to me you're countering yourself in several areas and if you were to set torque how it should be you might even possibly have self rev problems because of some of the things you've done.
    Torque is super negative (-53 lb/ft) - this can cause trans slipping - just a fyi... I assume to get idle timing up???
    Torque reserve is pretty high - part of the reason your idle timing is so low
    External Load is through the roof everywhere - probably a big player for the rev hang and another reason for low timing expecially in the off idle area for the rev hang
    I'll go ahead and tell you, the torque model is shaped wrong, but not horrible. Main wrong area is the idle. The big step up from that point can also cause throttle to hang
    Your VVE isn't fully dialed in. Make sure your setting the base temp when you flash it to ambient and reset the throttle before logging for corrections
    I didn't look at everything. Just those few main ones.
    ~Greg Huggins~
    Arizona
    268
    You may also want to revisit your minimum spark table. Not enough negative spark in those tables, which is contributing to a very slow return to idle.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
